What spring to use after mini tub/ & Wolfe spring adjuster? When the car is mini tubbed, I plan to use a smaller diameter spring, along with the Wolfe adjusters, to gain all the clearance I can get. What rate spring to use on a street driven car? Mid 9 sec car. I want something that is the same, or close to the stock spring. |
usually for a street driven car I use a 175lbs X 12" spring. |
Thanks. Who makes that spring, QA1? Can I get that through Thunder? Does that spring have a smaller diameter than the stock one? |
madman, for a strip car that sees very seldom street time would you reccomend that same 175x12 spring or something different? |
I've got a 150x12 under mine. I ordered mine through Spohn because I knew the part number (and I'm a dealer for them ;)). |
I will be more than happy to sell you the springs. I have either AFCO or QA1 in stock in the 2.5" sizes. On a drag car I usually use the 150lb. x 10 " |
© 2024 MH Sub I, LLC dba Internet Brands
