4 point harness install question
Is it customary to replace the rear seat bracket floor mounting bolts w/ eye bolts for the purpose of clipping the lap belt sections to the eye bolts? Bought a 4 point harness w/ no directions & see no other way to install the lap belt portion of the harness. Will need to buy eye bolts if this is the correct way to mount them. The lap harness has what appears to be eye bolt clips for mounting.
Posted in road racing section also. Sorry for the newb type question; just want to be sure. Thank-you
Originally Posted by 94z28L
are you planning on purchasing the "submarine" belt seperately or will these belts just be for show? just wondering
Found a reference install guide. It shows the lap harness bolted to the existing anchor points, in my case eye bolts in the rear seat mounts. Here's a link for anyone interested.
http://wescoperformance.stores.yahoo...seat-belt.html
Originally Posted by Fire67
If you read through that link it clearly says to mount your lap belts to the existing mounting points on the floor for the factory seatbelt.
Thanks for the comment & I should have been more specific.
