Here's some pics of the new setup! Here's some pics of my new setup its coming along now. Jerico should be here soon :drive: http://www.mofbody.com/forums/viewto...=379436#379436 |
Beautiful :hail: |
I can’t see whether you needed to notch the cowl. Is that the purpose of the spacer under the carb? |
how much more power do you see yourself making changing from EFI to carb? whats your E.T. goals for the new setup? |
i'm wondering what project 9 is, how much power do you really think the switch is going to net? |
I did have to notch the cowl it was a pain to get it looking the way I wanted it. The spacer isn't the best way ,but I wanted to run a Dominator. I'm hoping for 3-4 tenths all together with the Jerico also. Don't forget it will be on alcohol too. :drive: It should fly :judge: |
so does this mean you have a t-56 ram clutch sheetmetal intake and a a1000 for sale lol |
I did have its all gone already :jest: That means you need to go 9.70 and get that record :drive: |
shouldnt be a problem went 6.0 1/8 on motor, just need to get to a track... im down to 2950 w/driver |
Damn 2950 I wish my car was that light :eek2: Yeh you got it my best was a 6.21 at 111 in the 1/8. Good luck |
yup NA for now, I do have a race with a busa (streched built turbo'd) in ahhh say april, so i will see what she will do with the glide and alot of nitrous... but that will be the only time its an auto with that much spray... well maybe at the track to see if i could get a low 5 1/8th your car could be this light i still have all 4 seats dash and panels... and we have basically well had basically the same set up |
I'm hoping to lose some weight with the Jerico its only 68 pds so that will help some. |
is your cage mild steel or moly? there is a whole list of stuff you can take off on the top of this section |
Its chromemoly. I know I just like all of it looking stock :) Did you run that 6.0 in the 1/8th with the 6spd? |
redhatracer & Tosto Racing, ya'll need to keep talking. I'm try to learn something here! :) fuerzaws6 :drive: |
Ethanol or Methanol and what compression ratio? |
Methanol and its 15 to 1 comp |
Thanks for the info about my favorite drag car. It will be interesting to see how these latest experiments work out. |
timmy it looks like its going to FLY. have fun with it. i know you have been wanting to go jerico and alky for a while. looks great and good luck with a new best |
yes that was NA with a liberty shifted t56 spec 5 clutch adj master cyl and the drill mod slave |
| All times are GMT -5. The time now is 12:18 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
