Can you use a wire wheel on wheel studs?
I installed longer wheel studs yesterday since this and this would not pass tech or even be safe to drive on...
But I think I either buggered up the end of one of the studs or something because now it attempts to cross thread lugnut I put on there. I tried to have one that I thought was straight driven on and it cross threaded and almost ripped all the treads out of the lugnut. It was getting dark and cold last night before I could look it over too much but I think I just buggered up the first few threads and filled it with damaged parts of the broken lugnut. I was thinking of just hitting it with a wire wheel to clean up the threads, but not sure if I should do that or if there are other things that can be done...
You need to buy studs that have the ends that are not threaded like the stockers. This will allow you you to hit them and not mess them up. The ones you have are very easy to mess up when you put the wheel on.
Yeah, I would hate to have to buy another pack of studs because of one that is buggered up a little, and it was something I did because the lugnut I used to pull it on threaded down without issue so the stud was good out of the package but then I cross treaded the one lugnut and not nothing wants to go onto it...
I see that working if it was buggered in the middle, and has a few threads to run on first, but if it can not even thread on won't it just start cutting new threads and maybe be off a little when it goes down and mess the stud up further?
Most thread dies have an adjustment screw on them. You can open the die up a little to get it past the bad threads and then let the die close up on the good threads and back it off to cut the bad threads back straight. You can normally thread the thread die on from the end and get it lined up right. A thread file also works like ss590 suggested.
Well since it's dark out by the time I got home, and I don't have a garage I couldn't look at it, but after looking at the cross threaded lugnut I think the stud might be decent and just has crap from the threads ripped out of the lug lodged in it's threads or something...
These pics don't show it well, but the first few wraps of thread are almost wiped out and there is some of the thread just hanging in there...
http://www.1slowformula.com/images/c...readed_lug.jpg
http://www.1slowformula.com/images/c...eaded_lug2.jpg
http://www.1slowformula.com/images/c...eaded_lug3.jpg
http://www.1slowformula.com/images/c...eaded_lug4.jpg
http://www.1slowformula.com/images/c...eaded_lug5.jpg
OK, some guys on another message board wanted better pics of the damaged stud and lug to see if there was more they could add, so I figured to put them up here too...
http://www.1slowformula.com/images/damaged_stud.jpg
http://www.1slowformula.com/images/damaged_stud2.jpg
http://www.1slowformula.com/images/damaged_stud3.jpg
http://www.1slowformula.com/images/damaged_stud4.jpg
http://www.1slowformula.com/images/damaged_lug.jpg
http://www.1slowformula.com/images/damaged_lug2.jpg
http://www.1slowformula.com/images/damaged_lug3.jpg
http://www.1slowformula.com/images/damaged_lug4.jpg
http://www.1slowformula.com/images/damaged_lug5.jpg
http://www.1slowformula.com/images/damaged_lug6.jpg
After looking at them it almost looks like some of the lug threads ripped out and got embedded in the studs threads.
ARP wheel studs are $13 a pack (5 in a pack) for 2.5'' studs and I think $17 a pack for 3.25'' studs. I just bought the 2.5'' for all four corners from Jeg's.
On a side note, how long are the stock studs? I was under the impression that they were 2'', but I'm not 100%.
OK, you must have misread, one of the 3.25" studs I just finish installing is what is messed up. I was trying to get a few suggestions on what to do rather then spending another $25 for a pack of 5 when only one MIGHT be damaged...
Or how my father says: I see says the blind man.
You could always but another set locally (if possible) take one good one out and put your bad one back in the package then return it. Chances are they never check the thread quality just the quantity. Of course I would never do that. -Mark
