Does any sponsor sell backing plates for 9 inch rear? Wondering if any sponsor sells back plates for 9 inch rear. I would hate to go through the trouble of swaping them from the 10 bolt. |
Is there a reason you dont want to it doesnt take that long to remove not worth the money to purchase vs taking old ones off |
You may want to consider running LT1 rear brakes. They are alot smaller then the ls1's and clear drag rims better. I have a LT1 brake set up if your interested in it. PM me |
Originally Posted by Slow00ls1T/a Is there a reason you dont want to it doesnt take that long to remove not worth the money to purchase vs taking old ones off |
well I lack alot of mechanical skills and i was able to do it Pull brake calipers off Open up diff remove c clips if no traction control axles slide right out then un bolt them there alot of little stuff in between but that is the gist of it |
I think Billingsley used to sell backing plates. |
did you have the axles set-up to run stock brakes? If not you will need to send the axles back to moser to have the axles machined to work with the backing plates for the stock brakes. If the axles were set up for the stock brakes the backing plates are like $75-100.00 for the pair brand new from moser |
I just installed my 9" 3 days ago and went with Strange rear brakes. Perfect fit. |
© 2024 MH Sub I, LLC dba Internet Brands
