60 better, ET worse
60 better, ET worse
I am confused. I have gotten my 60 foot times fairly consistent in the 2.15 range. With that 60 foot time I have my best ET and trap at 13.84@101.75. After installation of drag bags (and 25 psi) my wheel hop is gone but my times are creeping up and are now around 14.2@98. Does an additional 10 degrees F make that kind of difference? Any other ideas?
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
Temp and condition changes can make 3-5 tenths difference between good cool air and bad summertime air. The drop in mph could mean a few things.
#1 Wind (likely headwind. 5 mph headwind can drop .05-.1 in time and 1 mph)
#2 Air (every 1000 ft of DA change can be around .1-.15 in elapsed time change)
#3 rubbing or drivetrain hp loss (Not sure what the new 60 foot times are, and the spinning could have kept the rpms higher than a dead-hook slow acceleration). Stock converter I'm assuming?
More info needed!
Derek
More info needed!
Derek
DA was within a hundred feet. No wind. Everything stock. Without pics I really don't know for sure on the spinning stuff. 60 foot has gone from 2.2-2.3 down to consistent 2.15. It feels like it is hooking better but I really don't know for sure. Also I didn't get a chance to compare the ET's at the intermediate distances. Also I saw on the GTO section that heat is a major killer so maybe that is my answer.
***Repost Police***
Maybe you're just doing SOMETHING a little different on each run. In my old Integra, my best run ever was 14.97 @ 93.82, and that was with a 2.37 60' time. I cut a 2.25 later the same night, but my et actually ended up being about a tenth slower. But yeah, temp can make a difference. Those runs were made at ~40 degrees, and when I went back in ~85 degree temps, I couldn't get any better than 15.4 @ 90mph
