Whats it take to run 9.99 NA?
I ran 10.82 stock shortblock with mild heads/cam.
At 3200 raceweight & all bolt ons, a TH350/400, 12 bolt w/4.30's what will it take for 9.99? The car will have 1 7/8 long tubes, race waterpump, etc. etc.
I'm shopping for a shortblock/longblock. I don't want to spend anymore than I need to get there. But won't build a cheap shortblock either.
What will it take to get there?
1) LS2 402/408 AFR/TFS 225 90/90 Combo
2) LS2 402/408 L92/L76 Combo
3) LS7 427 Topend?
4) LSX 454 LS7 Topend?
3) LS7 427 Topend?
So it is POSSIBLE to do without the LS7/LSx big motors? Just cathedral port heads & 90/90 combo?
FREE STUFF:
!Bumpers
!Spare
!Stereo/Wiring
!ABS
!AC
!Air Bags
!Side Door Bars
!I'm sure a whole lot more
!Carpet Pad
Custom Aluminum Seat Brackets w/removed recliners
$ MODS:
K-Member
Electric H20 Pump
Drag Wheels/Tires
That's all I can remember at the moment.
I have light carpet going in, a Sunoco Hood on now, will do lower control arms, and possibly drag brakes.
Originally Posted by John02Hawk
what weight reduction things have you done?
!Bumpers
!Spare
!Stereo/Wiring
!ABS
!AC
!Air Bags
!Side Door Bars
!Carpet Pad
$ MODS:
K-Member
Electric H20 Pump
Drag Wheels/Tires
a guy over here ran 9.8x with a 402, huge cam, 3000 lb weight, afr heads.
if i remeber correctly he made 460 rwhp.
look up "wajdi " + camaro on u tube and you can find it.
8 second mod
Im hoping to do it with my car. maybe faster.
i went 10.4 first passes on my new motor. never saw a dyno. i fired it up friday night, and went racing saturday.
im going solid roller and im hoping to go in the 9's next time out.
then i will spray it.
lsx block, 427, 14-1 compression, afr heads 3300 pounds
wrong gears and a glide. a gear and tuning would probably put it in the 9's as is, but i want more
8 second mod
Originally Posted by Specialized
Such a Noyzee thing to say.
Lol.
Lol.
"Never Satisfied"
psj, im still bound up with baby heads, and a fast intake.
this winter i will be doing a sheet metal intake speed dens tuning a big *** t-body then a better set of heads.
that all said and done, then im hunting low 9's.
right now im still running threw a stock maf, screen and all
I think a really solid 60 foot time is key when it comes to running 9's NA... I was hoping to see that last year with my hydraulic cam ETP LS7 427... I ended up with a 10.1 @ 134 with a 1.5 sixty... I think the motor had the power to run 9's but I had a switch to a glide with 3.73's and a nitrous converter... in other words, in order to get the best NA results you need a setup that is optimized to run NA...
I guess the real question is will a real solid 402 with TFS heads and a 90/90 have a chance at making it or will I need a bigger LS7 headed 427 or LSX motor to do it?
Originally Posted by Jantzer98SS
That helps. You definately have 9's in it with a good NA converter.
