M/T Et Streets 315 vs 325
I´ve been looking into buying either one but they seem so similar in dimensions
315 are 40lbs,13,4 sidewall,overall diameter is 29,8 and Circumfence is 94
325 are 36lbs,13 sidewall,overall diameter is 27,9 and Circumfence is 88
They both have 11" thread with measured on a 10" rims
The Queston is,are the 315 better?On the other side if the coin they are 4lbs heavyer?
I've been going through a similar situation. My issue was more about not wanting to hammer the inner fender with the 325. After some research I ended up going with the M & H 325/50/15.
Here's what I found minus the tire weights
M&H 325/50/15 Height 28" Tread Width 10.3 Section Width 12.3
M/T 325/50/15 Height 28" Tread Width 11 Section Width 13.0
BFG 325/50/15 Height 28" Tread Width 10.5 Section Width 13.0
For reference the M&H with the section width of 12.3 is the same as a nitto 315/35/17.
Originally Posted by Ari G
I forgot to rule out the tire height
I will be going with the 325´s but can´t understand why are guy´s using 30" slicks rather than 28" if we count out the height?
stevemilz,
How much work did it take to get the 315's in there?
I currently run 325 MT'S and it was a piece of cake to get them to work. I would like to go with the 315's but haven't had the desire to start the project. I assume some cutting of the bumber cover? Is there and cutting of the lower front 1/4 area in front of the tire? Wheel well stretching? its hard to see a good close side angle in your pics.
Well I am using the 325's also but recently swapped to 4.10 gears in the 12 bolt for motor passes so I am will have another set of rims with the 315's for n2o use. The extra 2 inches of height will help with the gear ratio plus added traction of the bigger sidewall for 250+n2o. I would also like to see what has to be done to make those fit. Later Clint
Originally Posted by jason99frc
stevemilz,
Its roughly $300 + repainting the quarters
The rear bumper get stretched also(you can keep the lips so it looks factory if you want)
"NOT MY CAR"
