LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Drag Racing Tech (https://ls1tech.com/forums/drag-racing-tech-34/)
-   -   These changes get me into the 10's??? (https://ls1tech.com/forums/drag-racing-tech/770760-these-changes-get-me-into-10s.html)
BTLFEDSS Aug 21, 2007 08:13 PM
More gear/or Bigger Stall??????????
Went to the track last week.Was not great weather,hot and very humid,DA 2500+
Here are my mods
Lid/Bellows
Ported TB
ASA Cam
SLP Lt's ORY/Cutout
Powerbond Plulley
100 shot 3k on/6600 off
Th 400
PTC 10" Nitrous Converter 2800-3k
10 Bolt 3.42
26x10.5x16 ET Streets
Car mad 321/323na & 431/430 on spray thru a TH400
100 Shot
R/T.678
60' 1.729
330' 4.848
1/8 7.442
1000' 9.669
1/4 11.570
MPH 119.09
2
100 Shot
R/T .833
60' 1.678
330' 4.834
1/8 7.445
1000' 9.691
1/4 11.586
MPH 119.06
Best run on motor Different Day before tune
R/T .046
60' 1.824
330' 5.206
1/8 7.987
1000' 10.391
1/4 12.416
MPH 111.23
Well my plans as of now are to send my converter to get restalled to either 4000 or 4200.Also to put a 12 bolt in the car possibley narrowed 4" with either 3.73's or 4.10's.I also am probably going to run a 28" tire,"325/50/15 on a 15x10 with a 5.5BS,not sure if this will help or hurt.Let me know what you guys think
BTLFEDSS
Pro Stock John Aug 21, 2007 09:30 PM
Wassah. I think your car should leave harder, it's a bit of a puss on motor. Have you messed with shift points on motor, I'd expect you to run more mph than that. What is your raceweight on motor?
I went 11.0 NA with 450rwhp @ 3500 raceweight. Our Pinks Camaro has gone 11.3 on motor on a crappy 1.60, hoping to crack a 10.99 in it on motor this year. on a 100 shot dry it's gone mid to low 10's.
BTLFEDSS Aug 22, 2007 04:03 PM
Well the coverters a nitrous converter and the stall is like 2800ish,whick is why i want to go to a bigger stall.Racewieght on all runs is 36-3700lbs,working on taking some wieght out.Also it is a RMVB TH400 shift every gear at 6500.I figured the car would at least go 12.0 on motor and 11.0 on spray.That's why i'm trying to make some changes.I would like to get the car to 10.7-10.90's
BTLFEDSS
BTLFEDSS Aug 23, 2007 05:23 AM
Decided on a Strange 12 bolt with 4.10's narrowed 3" on each side And some 325/5015's
BTLFEDSS
Villain281H Aug 23, 2007 06:13 AM
The gear change should help out, but she may be a bit more touchy on traction as it should leave the line harder. Keep us updated!
Derek
Pro Stock John Aug 23, 2007 08:01 AM
I'd run like a 4000 (on nitrous) stall or more.
Matt D Aug 23, 2007 08:18 AM
That converter is WAY too small, especially for a TH400. I would go with a minimum of 4000 like John said, but more like a 4500-4800 would be optimum.
Bryan @ Speed Inc. Aug 23, 2007 09:55 AM
4000 stall, 4.10 gear, 28" tire on spray. NOW WE'RE TALKING.
oh yea - AND GET THAT BITCH ON A DIET!
MrDude_1 Aug 23, 2007 10:00 AM
i would beat on your 60s until you atleast get down to the 1.5 range.. that will have you much closer... then up the power from there.
© 2026 MH Sub I, LLC dba Internet Brands
