m6/1.59 60ft or better
1.42 60 on motor 4.11's w/a 26'' tall tire. 6,500 to 7,000 rpm luanch.I was cutting 1.60-1.62 with close to a stock suspenchion. This was on the 346ci....My new 402ci should put me in the 1.3's on motor. ALSO,i have 5 years of abuse on my moser 12bolt....including 200nos shot out of the hole w/low 1.3 60's,no need for a spool. If it ever breaks,who cares look at how long it lasted.
my suspshion(nothing special)
hal q-a1's all around #2 in front #6 in rear.
bmr tq arm -2deg
lca's on bottom hole
bmr rear drag sway bar(no sway in front)
fraim welded.
M&H Racemaster 26x11.5x15 cheeter slicks and skinnies in the front. I feel the M&H tire is why I hook so well.
with some old 26x10.5x16 M&H tires on old junk yard rims I was close to 1.5 60's with only a bmr tq-arm everything else stock.
bmr tq arm -2deg
fraim welded.
Mine is a 3rd gen but basically the same... it has a 402 LS1, 6speed, and a 9".
no front sway bar
stock WS6 springs
stock replacement KYB shocks/struts
SFC's
LCA's
APHR
LCA reloc's
moser 9" with full spool and 4.11's
28x10.50 ET drags on Bogarts
26" ET fronts on Bogarts
Chris Alston tunnel mount tq arm
1.52 dropping the clutch at 6,000 rpm's
The car went a 1.51 with 325/50/15 MT DR's on 15x10 prostars.
Not much to my setup... works great with the stock springs/shocks.
no front sway bar
stock WS6 springs
SFC's
LCA's
APHR
LCA reloc's
