Suspension help needed, settings to get into the 10's
#41
I would either use a M/T or Hoosier drag radial, you can remove the front and rear bumpers, thats 40 pounds right there. FRONT IS OUT
Remove the passenger and rear seat when you go to the track thats like another 50 or so pounds. REAR SEATS ARE OUT, TAKING THE PASSENGER SEAT OUT IS CHEATING
Go on a diet thats 10-20 pounds lol. GOTTA PICK ON THE FATBOY HE HE
a/c and all the heater crap and ducting is a lot.A?C COMPRESSOR LINES AND CONDENSER ARE OFF
The strange front brakes drop 50 pounds off the front and you can run 15's without a spacer. NOT!
k-member and a arms around 35 pounds less. HAVE A FRONT K MEMBER
2 1/2" springs vs stock size springs. HAVE HALS UP FRONT WITH COILOVER SPRINGS
David
David
#44
Take out the rear bumper it is easy. 20 pounds
remove the heater box and ducting under the dash thats a good amount.
Ditch the power steering.
Take out the carpet and use lightweight speaker box carpet.
Use aluminum door panels.
lexan windows
fiber glass parts, whatever you can afford.
Aluminum block, heads and intake or composite intake.
lexan windows
#45
lexan windows
lexan windows
Its a SRTEETCAR!
The carpet has all the jute stripped off
Gotta have the heat, gets cold ya know.
Powr steering gotta stay
Aluminum door panels and Lexan on a streetcar...cant go there.
Has a fiberglass hood.
I am gonna take the door crashbars out, put in some Kirkeys and hell I dont know what else I can do to get some weight out.
David
#48
David
#51
#53
What driveshaft are you running? I am in the same boat as you except I swapped to a tighter converter and slowed down to 11.30's now. Except when I turn the n2o on next time out, I should skip the over the 10's. LOL
#57
LS1Tech Sponsor
Come on now, you know every fried chicken joint south of the Mason Dixon. LMAO.
I remember driving back from some race with you and you'd see a gas station up ahead and say "Damn! I bet they gots some gooood fried chicken up in there!!"
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
2016 Z07 Carbon
#59
I weighed the car on 4 corner scales, this is with a full tank of fuel and 15 psi in the right rear airbag.
No driver
LF RF
992 881
LR RR
743 854
With driver
LF RF
1099 913
LR RR
880 900
Thoughts?
Bryan, BTW, I have BFG 325/50 drag radials, can I rotate them side to side? There is no rotation arrow on the tire.
David
No driver
LF RF
992 881
LR RR
743 854
With driver
LF RF
1099 913
LR RR
880 900
Thoughts?
David
What's weird was I scaled my old nova on 4 corners and when I got in the car the weight only changed left to right 5 pounds.
