Should i go with 28's???
I havent bought wheels and tires yet. My Moser 12 bolt has 3.73's in it currentley. I am up for running a 26x10 if it suits the combo. The car will be setup for the bottle.
3.73's with a 26 inch tall tire is 141 mph. do you think the new set up will pop you up 10 mph?
how wide a tire do you run? maybe there is something in the 27inch tall range that would work with your combo and not take away the gear advantage. going to 28's would put the car having to trap above 142 just to get back to the shift point, much less pull clean through the whole power band.
BTLFEDSS
