Passenger Air bag removal???? I'm pulling some weight out of the car (94) and want to pull the passenger side bag. Is there a way to pull it without removing the complete dash? Any tips? |
Nope, you have to pull the dash in order to remove it. There's no other way around it. |
unless you have the hvac out. :) |
Thanks guys |
Matt, Here are pics from when I did mine so you can see what your getting into... http://www.1slowformula.com/HVAC-rad...lete/index.htm |
It's not that bad, just time consuming. Take your time and you'll be fine. |
My pics are here as well: http://www.scottsrides.com/smr95bird.html |
Thanks for the pics, looks like I'll pull the hvac out while I'm at it. If I get time I'm going to start in the morning. Looks like a ton of weight can be pulled under the dash. I just put a Grant wheel on and my K member should be here 1/2/08. Hoping to get the race weight to about 3400 lbs. I really want that 10 second NA pass. I'm also going to 4.11's with a spool over the winter and a dyno tune. |
Off topic.... what was the P/N for the Grant adapter for the steering wheel? |
Originally Posted by ecniv
(Post 8389169)
Originally Posted by matt94z
(Post 8388996)
Matt, Are you a bigger guy? The reason I ask is because I don't have the a lot of the lightweight stuff like K-member and all that and I have my race weight down to 3190#. I know I don't have a cage, but that will add about 90#, and I can pull more weight out then to bring it back down... |
Originally Posted by 1SlowFormula
(Post 8392281)
© 2024 MH Sub I, LLC dba Internet Brands
