Drag Racing Tech
Car Unloading Off The Line.
Old Feb 3, 2008 | 01:10 PM
JL ws-6's Avatar
Race your car!
If you have a wolfe swaybar on the car, get someone to sit in the car that's the same weight, or as close as you can get, then get under the car, and unhook the right side link. Adjust it so that the bolt holding the link to the bar can go in and out easily without any binding, reattach and then make the endlink 1/4 turn longer, and start there. That will slightly preload the car and should get it leaving evenly, that's how I did mine and it leaves dead even every time. Put the front shocks at 4 and the rears at 5/6 and see what that gets you. The 12 lbs is what I run in the 28x10.5S tires, but I'm not running tubes, your regular et drags with tubes arr probably similar, leave the air pressure alone, maybe go up to 13 cold for the first run. Start with the car like that, see what it does and lemme know, our track's prep is usually iffy at best, and my car leaves like this every run off the transbrake
Old Feb 3, 2008 | 03:04 PM
Taubr Unit's Avatar
Good info here. I did a lot of suspension to my car as well and im sure it need a lot of tuning. Will get to the trakc here in about 2 months so i got time to research...
Old Feb 3, 2008 | 04:35 PM
JL ws-6's Avatar
Race your car!
The way I describes setting the swaybar has worked for my car very well, one thing I did forget to mention, is the chassis rideheight. I have removed the rear spring rubbers and insulated the spring with a piece of hose to supress teh noise, this lowered the back of the car roughly a 1/2 inch. I also lowered the frotn about 3/4 an inch fron what the car was stock, and I made sure both sides in the front are even without anyone in the car, measuring from the center of the fender (thru the wheel center with the tape measure) to the ground.
Old Feb 4, 2008 | 12:26 AM
TwoFast4Lv's Avatar
My fix for this was very easy.
I just put on a set of DA front shocks
Old Apr 11, 2008 | 08:30 AM
dnkynrbk's Avatar
Hey pulling out the spring isolaters today. Then adjusting the rollover bar. thanks Heading to KC MO. to race sunday so I will see what happens
Old Apr 11, 2008 | 10:57 AM
TwoFast4Lv's Avatar
I will be there next weekend
Old Apr 11, 2008 | 01:28 PM
dnkynrbk's Avatar
took out the spring isolaters now Its sets 28 in the rear and 26 1/4 in the front
Old Apr 11, 2008 | 02:37 PM
94 guy's Avatar
how hard is it to take the spring isolators out?
Old Apr 11, 2008 | 02:47 PM
JL ws-6's Avatar
Race your car!
jack up the back of the car, get the frame on jack stands. Jack up the rear enough so that you can unbolt the rear shocks, then lower the rear down, the rear will now hang down past where the shocks normally hold it to, and the springs will come right out. Take the spring isloaters out, put a piece of hose over the first coil of the spring, replace springs on to the rear housing, jack rear up and reattach shocks.
Easy, takes about 45 min of you're doing it alone with no air tools, from the time you jack up the car ot the time it's back on the ground
Old Apr 11, 2008 | 02:54 PM
dnkynrbk's Avatar
just did it dam its easy. I went to your local automotive to get the hose .98 a foot and used WD-40 to lube it and its slide right over. you may have to push the bottom of the springs up to get them off the rearend with your hands.
Old Apr 11, 2008 | 05:40 PM
StreetStalkerZ's Avatar
What size is the hose you used to slide onto the spring?
Old Apr 12, 2008 | 02:00 PM
  #32
rmata's Avatar
I used 5/8 for mine. Gives you a little extra room to help it slide around the coil.
Old Apr 12, 2008 | 10:38 PM
  #33
RAGENZ28's Avatar
How many holes do you have to adjust your torque arm and do you have relocation brackets?
