2500 race weight here i come
current is 2799
i still need-
manule drag brakes- ~100lb's
extra metal- ~25
extra wiring- ~10
rear bogarts- ~40
a-arms- ~15
manule rack- ~10
glide- ~30
that makes it ~2569
add a 8 point- ~75
that then is ~2644
then i still can do a vfn hatch and lexan window- ~100
then a windshield- ~50
and bam 2500. actually less cause i can think of some other **** i need to still do
i still need-
extra metal- ~25
extra wiring- ~10
rear bogarts- ~40
a-arms- ~15
manule rack- ~10
glide- ~30
that makes it ~2569
add a 8 point- ~75
that then is ~2644
i heard some people say you can installthe lexan into the stock regulators and roll up and down now i assume youd need to hold it or roll it up while the door is open
manule drag brakes- ~100lb's ---- is this front and read because the fronts were only 64 i though?
a-arms- ~15 -------?? i think the uppwer are the same as stock weight...the lowers sve 2 pounds each
manule rack- ~10 -----the rack itself is heavier than stock...the ps pump might weight 10 though....
then i still can do a vfn hatch and lexan window- ~100 ------ hatch and window i think might be 80...i think the glass is about 65
then a windshield----- ~50 front window is prolly 40
i wanna know whats all missing to get it 2799 with you in it? or are you saying the cars weight itself?
Retired Street Racer
Hopefully one of those with the pin-on hatch and lexan, both front and back, will chime in. It is not 150lbs. I know that. I inquired about it a while ago, and it was a lot less than that.
A-arms you won't save that much. I swapped out my stock k-member and upper & lower a-arms, and it saved 40lbs total. All of it was chrome moly too.
Rear Bogarts won't save you 40lbs unless you have 22"s with high profile rubber on your car now. Remember you still have to put rubber on the rims...
And drag brakes don't save 100lbs. It is 25lbs for the back and 50lbs for the fronts (65lbs if you do an ABS delete and manual master cylinder with it).
You could run the chrome moly spindles for the front. Those save 30lbs over stock and allow you to run 1st gen brakes which are cheaper. That is what I am doing.
My car is 2800 right now and I still have to do the drag brakes all around, spindles, manual master, ABS delete, fab 9", Speed Glass, pin-on hatch, door bar removal, and a few other misc brackets that I need to cut out.
brakes- i want to do the lighter spindle setup. otherwise everything is 65. i wil be doing manule master and abs delete at the same time.
a-arms- i didnt think they weighed that much eaither, but the list above says otherwise.
manule rack- the weight list says its 10. i thought i read somewhere it was about that much in weight differnence
rear hatch/lexan- maybe, last time i searched i came up with close to 100
windshield- that was a complete guess
2799- is with me in it right now
I have 17'' waggon wheels in the back. with a DR. I willl switch to a bogart with a bias ply.
thought of some more
-mezier electric water pump
-radiator, found a race one for 6.5 lbs. Does anyone have the weight of a stock one?
-single fan, should be good for another 5 or so
does anyone know how much a madman TA weights? I have a heavy *** steel sphon TA
need to cut-
frame in front of k member, or at least hole saw it
cowl area
a few other random brackets
make a lighter dash brace, im sure there is some more weight behind it i can find
maybe mini-tub
im sure i can get creative in a few areas that come to mind...
need to cut-
cowl area
maybe mini-tub
badass 2799 with you in it...thats great...i figure you can get one down to about 2550 without some1 in it but thats about it...then you can do lexan on top of that...
btw stock radiator doesnt weigh that much...i doubt its 6 pounds even...
id like to know exactly what all youve taken out though...your goana get that ? a lot so might as well list them now if you do PM it to me keep this thread clean
I only weigh 120-130
I picked up a lt1 radiator which is a little bit thicker and it weighed every bit of 15-20 lbs
for a list it would really be a copy paste of the weight reduction list.
Maybe these pictures would answer any questions.
If you are wondering about any specific parts let me know
