Q1 1 COILOVERS R what height on the spring
On QA1 R with 275 lb spring. How much the spring do you compress up on the shock with your spanner wrench. Mine is from the bottom of the shock bracket that bolts to the lower a arm its around 7 1/2 inches to the spanner washer. thanks
"All Motor 9 Second club member"
I think mine were at 7 inches,but we also ran a 315# spring with the iron blocks extar weight.
You really should adjust the front end height to get the car somewhat level depending on how tall your front and rear tires are. I'm an inch lower in the front.
G/L
G/L
It's easier to lower than to raise.
Set it high, take it for a quick run around the block to settle then adjust as needed.
7.25" was about where I ended up. (started at 6.5" and raised )
