How much will I gain from these mods...Take a guess I just ran a 12.17@112 last week at TNT with no track prep Now Ive got: ASP Crank Pulley FTRA Kit Wolfe Torque Arm Eibach drop 1.5 in Wolfe Sub Connectors Raised the limiter from 5900 to 6400 Oh and Im going on Friday when there is track prep. Take a guess, Im guessing a 11.8@114ish??? :secret: |
Re: How much will I gain from these mods...Take a guess What kind of tires? Let's see, cam, heads and 100 shot + track prep + ET Drags = 10's :devil: See my signature for 100 shot on stock head/cam (A/D 4,800+). David |
Re: How much will I gain from these mods...Take a guess Good numbers. I have MT 26X11.5X16 ET Streets But I wanted to know what I would run on motor, Not Nitrous. From the 12.17 and with what I added what do u think I can squeeze? ^^ |
Re: How much will I gain from these mods...Take a guess Why is your rev limiter only at 6400? That X1 can use some more rpm. Take it to 6800 or so. You should be mid 11's AT LEAST with that setup all motor. Larger tires will help, but then you'd need a gear change. I'd say the mods you added should drop a tenth or so. But the rpm change will help a lot. |
Re: How much will I gain from these mods...Take a guess The lowering springs won't help the cars launch....but it should be in the 11's... |
Re: How much will I gain from these mods...Take a guess Thanks Guys, Hope to see 11's. |
© 2024 MH Sub I, LLC dba Internet Brands
