outlaw ez street suspension
hey guys im got all my suspension but not the rear springs in my car i got qa1 single 12 way adj shocks all the way around all bmr front suspsension ive got adj chrome moly rear suspension with the rodend and im gonna get the wolf racecraft antiroll bar and im got 315/60/15 mt radials with 3.90 gears for right now and a powerglide with transbrake and 5000 stall hoping with nitrous will make about 850 to 950 to the ground or maybe better i just know the dyno dont mean nothing i will hurt your feelings so let me know how to start setting it up before i go to the track or how yall got your cars setup
275# front springs, set with r shocks on #2 with travel limiters set to 2.5".
Rear shocks are set 50/50 rate.
Rear springs 150#
My instant center is 48" x 5" off the ground.
Rear fender is 26.75" off the ground with a 29" tire.
Front is 3/4" lower than the rear.
Weight dist is 52/48.
I run a manual, since you have an auto I would recommend your instant center a little higher, maybe 6-7" off the ground to start.
Rear springs 150#
Rear springs 150#
Rear springs 150#
How fast did you go with that set-up?
i know i wont run with them just my local tracks i think the track record around here is like 5.49 in the 1/8 and i may put down more power then then 950 hp i just know that dyno number will hurt your fellings i allways went to the track before i went to te dyno
well i got the motor from a guy who had it in a rail that did that dirt track 300 ft racing but the motor is a 496 with manly aluminum rods 15.1.1 manley pistons it had stock heads that had port work done to it i took them off and had them flowed and only did 217 and 353 at 750 lift so i am getting rid of them im gonna get some them bmf heads with the 350 intake runners thet flow like 420 the cam is solid roller but im gonna get a cam to match the heads maybe with 112 to 114 lsa and its got a 1250 quick fuel carb crank trigger ign with 7al2 box the weight was 3240 with me in when i had a small block and ive took alot more weight out to make up for the bigblock because every think in my car did work with the small block so i hope for 3250-3300 the transmission is a jw performance glide with a hughes 5000 stall and i do have a tighter stall if i need to use it and and im gonna try to spray at least 250 and might get another stage but on suspension stuff i am all ears to u and brady after i seen what yall did on drag radials i u two guys
About as fast as I can push it in and out of the garage, 8-10 seconds at 1-2 mph?
I was just giving you an example of what I had mine is under construction still, I will one day when someone drops a bag of money on my door step run a procharger with a 15x12 with a 31 or 30x11, and make 800-900 hp on pump gas, then run it on race gas and add some boost and rip some passes at the track. It's my ultimate quest for a kick *** fun street / strip car.
Do you have any photos yet?
