QA1 325lb. front springs?
I'm needing to change the front springs out to lift the nose back up. Right now the nose is setting very low with the weight of the iron block setting on it and im having a problem with the rear suspension unloading from time to time and i think it's because im not getting enough travel or weight transfer with the stock springs on the front with the heavier block. Will these springs help me with lefting the nose up a tad more and help more with weight transfer?
I have a set of AGX adj. shocks on the front for now and they work well enough for me to cut 1.43 60ft. to average 1.45-1.47 60ft. so im not looking at changing shocks right now so now my attention is turned to QA1 springs for the front and competition engineering 50/50 shocks for the rear to give me a decent all around setup.
Im intrested in this to I have the iron block in mine and have the qa1's with the 275 springs.Should I go with a stronger spring? I recently had a shock blow out a seal had about 10,000 miles on it though.
