LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Drag Racing Tech (https://ls1tech.com/forums/drag-racing-tech-34/)
-   -   What to set rear QA1's at (https://ls1tech.com/forums/drag-racing-tech/878502-what-set-rear-qa1s.html)
JUICED96Z Mar 8, 2008 03:59 AM
What sould I set my rear QA1 shocks at?
BBC third gen, Lakewood drag shocks up front, full suspension out back.
Right now I have them both in the middle (can't remember the number)
Thanks
borninatransam Mar 8, 2008 04:41 AM
about 5 or 6 is right in the middle or 50/50. thats where most people find the sweet spot. really youve got to take it out and test. but chance are you're not going but 1 click in either direction from there.
James Montigny Mar 8, 2008 07:15 AM
I've had the most luck with them on the fourth firmest setting.
omcar Mar 8, 2008 08:33 AM
I bracket race mine all the time at 3 left and 4 right..gets me a 1.57 60' with a stock motor and 3.73s /3,600 vig.
davered00ss Mar 8, 2008 01:17 PM
I set mine @ 3. But you have to find what works for your set up. I'm a 6 speed with Nitto drag radials & a 10 bolt.
omcar Mar 8, 2008 02:56 PM
a 3 setting worked good for me as well.
JUICED96Z Mar 8, 2008 08:22 PM
Im going to try and get it to the track soon so I will keep them in the middle and go from there, I figured most guys had them at 3-5.
James Montigny Mar 8, 2008 10:12 PM
Are you guys counting up from firmest or softest ?
ZV8 Mar 9, 2008 03:54 AM
A BBC is gona weight down the front a bit more than SB, I would leave a little room to squat that rear end to make more weight transfer
© 2026 MH Sub I, LLC dba Internet Brands
