Drag Racing Tech
Setting up Hal's
Old Jul 20, 2003 | 09:02 PM
furely's Avatar
Default Setting up Hal's
I just installed my front and rear Hal shocks and am using the Hal springs up front. My question is, where do I set the springs at. I have a spring compressor so it shouldn't be hard, I just don't know where to set them. Any info would be appreciated. Thanks
Old Jul 20, 2003 | 09:30 PM
Kent1's Avatar
Default Re: Setting up Hal's
I would set the springs to achieve the same height as it was from factory. I measure the lenght in inches from base of tire to fender well on both sides of car and set the springs accordingly. I like the factory height because the car is already low as it is. But you can have the car lowered if you want. Just my thoughts.
