aerospace rear brake users
my rotors are very slopy on the studs and there not centering them selfs. im runing 1/2 20s studs and its like my rotors have 7/8 holes. i whould not be concerend but i had a very bad vibration on the dyno
A lot of brake rotors and drums have some play in them, usually some of the holes are 1/8" bigger, as long as you torque them to the right spec you'll be ok. Mine personally fit on the tight side but I've seen a lot of those that fit loose my friend has a tire shop and does brakes and a lot of factory setups are like that, I wouldn't worry about it.
