LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Drag Racing Tech (https://ls1tech.com/forums/drag-racing-tech-34/)
-   -   DR's sidewall?? (https://ls1tech.com/forums/drag-racing-tech/897648-drs-sidewall.html)
BlackSS2001 Apr 7, 2008 02:30 PM
DR's sidewall??
Ok I'm needing to just go on and buy some DR's just a quick question.
Should I find a 15" wheel of just use my 17" Wheels?
Should I use a smaller wheel diameter so I will have a larger sidewall?
If I went with a 15 it would be a 15X11 insted of my 17X 9.5 to that would be better just because I would have more surface area..
I read the sticky and got this but I don't think it really helps me...
Question: What is the advantage to running a stiff sidewall tire? If there is no stiff sidewall slick in my size what can I do to stiffen the sidewall of my slick?
Answer: The advantage of a stiff sidewall is less tire wrap or sidewall distortion, thus reacting better at launch. Note: This is good for heavy cars, or cars with a suspension, that can absorb the initial launch. If you are running a fixed suspension car like a dragster or an altered, you would need the tire to absorb the launch, thus a softer sidewall. There are two ways to stiffen the sidewall. 1. Run tubes to help support the sidewall. 2. Matching the tread width with the wheel width, or going 1 wider on the wheel width, will stiffen the sidewall
bad2000z Apr 7, 2008 09:13 PM
Get 15x10 Draglites with 7.5" backspace, and 275/50 (26") or 275/60 (28") M/T DR's.
BlackSS2001 Apr 8, 2008 11:31 AM
are 28 the biggest you can fit in there?
how tall is a 325/50/15?
trigger1 Apr 8, 2008 11:47 AM
325/50/15 is like 27.9" tall I believe. It's what I run on my car.
trigger1 Apr 8, 2008 11:48 AM
http://i46.photobucket.com/albums/f1...319081905a.jpg
http://i46.photobucket.com/albums/f1...319081905b.jpg
http://i46.photobucket.com/albums/f1...0319082201.jpg
BlackSS2001 Apr 8, 2008 11:50 AM
I have a set but they were only a half inch away from hitting the rear bumper and the front of the wheelwell.
trigger1 Apr 8, 2008 11:54 AM
Radial tires don't grow like a slick so I'm not worried about it. It's very tight on my setup on the inner wheelwell.
BlackSS2001 Apr 8, 2008 12:14 PM
ok I was just checking.
LS1crazy01 Apr 8, 2008 05:36 PM
Yah deffinaley get yourself some 15x10's for that size tire. By the way 28's look amazing on F-bodys.
© 2026 MH Sub I, LLC dba Internet Brands
