6 point bar cost?
My vote is for mild steel. The low slung side bars aren't that hard to manage getting in and out, but for a DD swingouts may be the way to go.
Another thing to consider is over the back set rear bars or standard rear bars. If you go standard you can't mini-tub with that bar. But if you go over the rear seat you have to drop the gas tank to install a bolt-in.
Is it worth it to spend 120.00 dollars more to save 20 pounds, compared to other weigh reduction pieces yes. Look how much a set of upper control arms cost and it doesn't even save 10 pounds.
If you care about having the lightest stuff and are serious about racing then moly is the way to go, if you're a guy that wants to be track legal and don't care about every pound and going as fast as possible, then mild steel is better and you can invest the difference in other performance parts.
Moly will always have a higher resale value. I like the wolfe stuff and a few other companies, but honestly with the prices of freight right now having a custom built roll bar would probably end up being close to the same price.
Derek
I will be going with the CM. That wasn't really my point. Just looking for some options. The money, as mentioned, is well spent to not gain an extra 20lbs.
