Ride hight/ To much rake with 28's for weight transfer? Vids in HD
Front shocks are strange singles. no front sway. Rear is stock springs, heater hose upper insolator. Stock shocks spohn 1inch rear sway, no airbag. On stock wheels, about 25.7inchs the car sits about 1/2 lower in the front. But I noticed with the 28s on the rear the car has a LOT more rake, and was wonding if its to much for tranvering weigh???? and I should get the to sit more level?
car on 26s stock wheels, 60's are 2) 1.7s, a 1.8, and a 2.0![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
http://vimeo.com/1822370
on 28s: 1st time on them checking if they rub![Angel](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_angel.gif)
http://vimeo.com/1800994
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Well thats was the 1st and only 3 passes on that wheel setup. I know I need more seat time, and will work on what rpm and all that.
Just noticed in the vids the amount of rake, and in the top video at night. I could see the car tranfering the weight good. And getting some really good 1.7s and low 1.8s on thosue tires. Made me wonder what rake is too much?
ttt
6K dump vid at the end
https://ls1tech.com/forums/drag-racing-results/997457-new-best-11-2-122-cam-only.html
had the shocks on full loose, I htink I need to tighten them a bit? or cahnge the TA so its not hitting the tires as hard and unloading?
