Old Valvetrain (YT Rockers) vs new PAC valvetrain dyno (w/stock rockers)
As many of you saw my previous thread with new numbers and some severe valvetrain issues up top.
Well I decided to go with PAC 1518 springs, ti retainers, and switching back to the stock rockers. I ended up needing shorter pushrods as well.
Before numbers are with the laboring Patriot duals, yella terra RR's and 7.425 pushrods.
New numbers are the PAC 1518's, comp ti retainers, 7.35 pushrods and stock rockers.
Both are SAE smoothed to 5, the before CF is 1.00 and the after is 0.97. Going to try and get the run files so I can do some more overlaying and see what the car was actually making.
Here is my other thread I was referring too: https://ls1tech.com/forums/dynamomet...er-change.html
Note that with 440rwhp and 400rwtq the car went 7.01@100 in the 1/8th
LS1Tech Premium Sponsor
What camshaft? Not surprising that a heavier rocker and incorrect pushrod length could cause that "laboring", IMO....what test did you do to isolate the three parts changed to see which made the difference? What install height were the Patriot springs at? And the PAC's now?
I don't want to sound like a dick, but the title makes it sound like PAC springs fixed your issues, when in fact you changed at least 3 variables in the valvetrain that each could have contributed to the problem.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Ask Jonathan at Tick if you want all those details to blame the problems on. The fact is the pushrods were ordered to spec of the size needed and the yella terras were shimmed to fit perfect and have the best wipe pattern. Sorry I don't just order the "standard" 7.4 pushrod that "most" vendors send with their cam packages.
He tested the previous springs and they varied in heights as much as an 1/8" standing beside each other and the springs varied from 120-145 lbs on the few that were checked at 1.780" where they were installed. Hows that for putting your argument to rest?
The cam is a 230/236 .613/.609 111+1 xfi lobes. Anything else that you feel the need to defend?
I don't need to defend anything...I don't have a dog in the fight. Just curious how PAC is the hero on the deal when there were at least parts changed? We deal with Tick all the time and they are great guys to deal with. Did they spec your old valvetrain setup and install it? I'm not blaming anything on anybody, just hoping people reading here don't think that somehow the PAC springs were the end all be all fix for your issues, when they weren't necessarily. The fact is, it could have been the pushrod length, rockers, AND/OR springs.
Why so defensive about simple questions?
__________________
The reason I say it was the springs because of the tests done with the springs. If the springs tested ok I would have kept them and saved my money but they fact is they were bad, really bad. I had planned to put the YT's back on but I just wanted to get the car back and enjoy it. If you think I could have gotten the same results with the Patriot springs by just switching the rockers and pushrods then somethings wrong!
Why so defensive? Because you jumped in here and started blaming it on improper setup when you didn't know anything about it.
If I blamed it on something that hadn't been tested then assumptions could be made but thats not the case here.
And I know its a quick swap to switch out the RR's but my car needed to get off the dyno for the swap and it would have been another day or so before the tests could get done. I was too anxious to drive the car since its so nice out.
__________________
No worries. I know what "camp" you hang with when not on LS1tech, and I really wasn't attacking you for it. Purely curious with no alternative agenda here!
__________________
LS1 Tech Administrator
The shorter pushrod makes sense if you went from a Yella Terra to a stock rocker. The YT rockers typically give the best wipe pattern with a .050" shim (which the stock rockers don't need). What plunger depth (pre-load) did you choose for the lifters? With a 7.350" pushrod, I would assume your pre-load is shallower than stock.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
I don't really have a "camp" I'm everywhere. I also run your head and have been going pretty quick/fast with it. Do I think I have a good chuck to gain with a newer/better casting yes, am I going to swap? Nope not until the cubes go up.
Cool, glad to hear. Best of luck!
__________________
Wow! That is great!
I'm amazed how similar our graphs are considering the variation in our heads and cam choices/specs.
It looks like the slight dip at 4,000 rpm might be related to the Air/Fuel mixture getting a bit lean? I noticed the A/F ratio drops at that point and mirrors the power output step for step. I'm surprised Alvin wasn't able to tune that out? Must be something more happening there.
I didn't remember you're cam was a 111 LSA. That thing must cam pretty hard! Can't wait to hear it one day.
What tires are you running with this setup?
Congrats!
Congrats!
Wow! That is great!
Congrats!
Congrats!
The actual dip from 3600-4000 is from it running rich, not sure why it didn't get tuned out but other than that the car is running great. Idling at 875ish and pretty mild street manors for the setup.
