**UPDATE** 520/474 H/C/N2O through TH400
(( UPDATE ))
Original thread "old graph attached":
https://ls1tech.com/forums/dynamomet...ugh-th400.html
N2O section thread:
https://ls1tech.com/forums/nitrous-o...rt-inside.html
Had the car dynoed again after we figure out the problem which was low bottle pressure, this time we get a brand new bottle and a heater, the bottle pressure at the dyno was ~ 1000 PSI. The first run was NA and it made 435RWHP/420RWTQ and 521RWHP/474RWTQ best run on spray. However, the last dyno#s were 433RWHP/489RWTQ on motor and 490RWHP/570RWTQ on spray.
I would like to thank Mark "Predator-z", Patrick G "TR", John Janz "TSP", Greg "FTI" and every one supported me.
The Mods are: TR custom cam speced by predator-z, TSP-PRC 5.3 stg 2.5 heads, TH400, custom 4000 stall by FTI, TNT F2, 3.73 gears, LS6 intake and Full bolt-ons.
So now what do you think guys? Is it fair enough and every thing was ok (AFR, peak HP, peak TQ) ?
Charts:
New N/A run "open cut-out"
New N2O run "closed cut-out"
Last N2O run "open cut-out"
I will try to get the graph in MPH from the dyno this week if possible.
Yeah I've noticed the dip after the 4000 RPM in all runs. Is it normal with the 4K stall or there is something wrong? It should be noted that the nitrous works at 4200 RPM and it shuts down at 6000 RPM.
LS1TECH & Trucks Sponsor
IMO, your N/A power is pretty stout considering the drivetrain you are running. I am a little confused about the nitrous power. I would make sure and check all the grounds associated with the nitrous to make sure they are all properly installed. Let us know how it goes!
LS1 Tech Administrator
I'm surprised to see you running 12.5:1 A/F ratio on the the nitrous. IMO, that's dangerously lean for anything longer than a dyno pull.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
I can not figure out what may be the problem with nitrous, I don't like the numbers nether.
