Iron Block 370 W/ L92 Heads, L76 Intake
Old 05-14-2010, 01:24 PM
Mikey 97Z M6's Avatar
Default Iron Block 370 W/ L92 Heads, L76 Intake
I just recently assembled a forged 370 for the black car (1997 Z28). This car is mostly a drag car so I don't really care about drivability etc... Eventually I'll be switching the intake manifold to a single plane Vic Jr w/ 4bbl style tb. Here's a rundown on the setup and numbers it put down last night after some tuning. This was done on a Mustang dyno also.
-LQ4 Iron Block
-Mahle -2cc Forged Pistons
-Compstar H-beams
-242/250 .611/.619 114+4 (Old Speed Inc Grind)
-GM MLS Head Gaskets
-Self Ported L92 Heads (exhaust flows very well) Milled .028"
-Self Ported L76 Manifold
-36lb SVO Blue Top Injectors
-NW90
-Custom 4" Intake w/K&N Cone
-1-3/4" Grotyohan Headers
-Custom 3" True Dual Exhaust w/ Summit Bullet Mufflers
-T56 w/ Monster Level 3 / Billet Steel Flywheel
-9" Rearend w/ 35sp Axles and 4.30 Gears
-28-10.50 MT ET Drag Slicks
Baselined the setup with my old tune file from the 387 and it put down 474rwhp with a few degrees of kr up top and was pretty lean. Added some fuel to the tables and she jumped to 482, did the same thing and jumped to 486. Took out 2 degrees of timing up top (my suggestion to the tuner), added some more fuel and she got:
490rwhp @ 6600
437rwtq @ 5300
We stopped the dyno session because on that last run we hooked up a fuel pressure gauge and saw the fuel pressure dropping after 4600rpm. It was only 33psi at 6700rpm. Time for a new fuel pump lol....
http://www.youtube.com/watch?v=Ti0zoMlMonI
I'll try to post up the graph here in a bit..... Overall I'm pretty happy with the numbers for such a small cubed engine.
Mike
Old 05-14-2010, 01:27 PM
buzz12586's Avatar
Nice numbers especially on the slicks.
Old 05-14-2010, 01:31 PM
StreetSilverado's Avatar
-LQ4 Iron Block
-Compstar H-beams
-NW90
490rwhp @ 6600
437rwtq @ 5300
Mike
I'd recommend going with some 42lb's soon. Mine are at 75%-78%, but I guess you'd know to look at the IDC
Old 05-14-2010, 01:47 PM
I was asking the tuner about that also. We need to get the fuel pressure under control first though....
Mike
Old 05-16-2010, 02:33 PM
LS6
LS6's Avatar
nice set up.
from what I see from the other threads, you will be hitting the 530rwhp wit the following:
-cam of 228/235
-1 7/8 headers
-Fast and TB
Old 05-16-2010, 06:41 PM
-cam of 228/235
-1 7/8 headers
-Fast and TB
A naturally aspirated 370 with a 9" rear, drag slicks, and on a Mustang dyno hitting 530rwhp? .......... ? Please post a link to that lol....
Mike
Old 05-17-2010, 04:33 PM
LS6
LS6's Avatar
I will try to find the threads...
Old 05-17-2010, 09:02 PM
MikeG's Avatar
Maybe a 408, not a 370...
Nice numbers and build. I can't wait to start on my 370.
Old 05-31-2010, 03:01 PM
Spectre86's Avatar
glad to see you got everything together mike. congratss. nice numbers as well.
whats the CR ratio? feel like touching up my L92s?
Old 05-31-2010, 05:02 PM
BrianC98Z28's Avatar
can you get a pic of the 4in intake with filter?
Old 05-31-2010, 08:09 PM
Johnnystock's Avatar
Stock fuel pump I guess? its pretty good that you pulled passed 450rwhp...dangerous though!
nice setup!
Old 06-09-2010, 11:43 AM
Thanks man. CR is pump gas friendly at around 11.3. She snapped the forged 1350 transmission yoke the first night at the track lol...
Mike
Old 06-09-2010, 11:46 AM
Here's the custom intake setup I made for it,,,, there used to be an LT1 in there. The stock LT1 elbow off the the TB fits the NW90 perfectly so I re-used it. Also, the ABS delete eliminates clearance issues with the larger 4" piping.
Mike
Old 06-09-2010, 11:51 AM
nice setup!
Yeah stock pump, and I know it was dangerous, although there never was much KR. The tuner kept adding fuel and adding fuel and finally I was like; "Maybe we should check the fuel pressure?" LOL....
Mike
Old 06-09-2010, 12:41 PM
MYSTIC-1SC's Avatar
nice numbers.
Old 06-09-2010, 05:24 PM
MASS seller approved
smok'nZ's Avatar
i think tsp has a GP on 1 7/8" LT's there is your 500 mark
Old 06-10-2010, 01:05 PM
I know huh.... I wish I could afford some larger headers right now.
Mike
Old 06-10-2010, 03:30 PM
Nitroused383's Avatar
Nice results, but I believe you have an easy 10-20 rwhp left on the table with your intake setup. 90 degree elbows have been known to kill power, especially on the GTO's and yours is similar. If you can come up with an over the radiator type intake setup you would gain a bit. Good luck at the track, this Washington weather is making me go insane!
Old 06-10-2010, 05:42 PM
I've considered going SD on the tune and ditching the 85mm MAF. Eventually I'd like to go with a single plane 4bbl style manifold.
And you're right, this weather here is sucking....
Mike
Old 06-13-2010, 02:29 PM
odarabla's Avatar
Nice numbers man.
Quick Reply: Iron Block 370 W/ L92 Heads, L76 Intake
