Notices
Bone stock 5.3/ebay turbo/6psi
Old 11-30-2011, 09:34 PM
Nice build! I'm doing something similar in my third gen with a 4.8, 76 mm turbo and ls9 cam. Mounted turbo in the same spot you did. Where did you find room for the wastegate?
littlereds10 is offline
Old 11-30-2011, 10:00 PM
Fondle's Avatar
plenty of room for a wastegate coming off of the merge, even have a dump pipe on it too
Fondle is offline
Old 12-01-2011, 05:37 AM
Is the merge right at the turbo? I guess mine is a little different because my manifolds are upside-down
Old 12-01-2011, 06:15 PM
Fondle's Avatar
no its a little before the turbo, Mine merges into a 2.5" pipe for about 6 inches before the turbo
Fondle is offline
Old 12-04-2011, 07:22 PM
supersick99z's Avatar
What A/R is the gt45?
supersick99z is offline
Old 12-11-2011, 01:51 PM
this is an engine dyno right?
71 chevy is offline
Old 12-13-2011, 03:05 AM
camarodude87's Avatar
Nice *** build... Im pretty jealous
camarodude87 is offline
Old 12-13-2011, 08:06 AM
Old Geezer's Avatar
Default The printout
would appear to be from a chassis dyno run..If so, REALLY impressive!
Old Geezer is offline
Old 12-13-2011, 09:39 AM
the math works for an engine dyno, not so much for a chassis dyno.
say 325hp in stock form with 6psi is 457 at the most. At the flywheel. thats why i assumed it was an engine dyno.
71 chevy is offline
Old 12-13-2011, 06:23 PM
Nice numbers, you plan on getting track times?
mustangless is offline
Old 12-13-2011, 11:08 PM
TyCZ28's Avatar
Those numbers were from a Dynapack dyno at RPT of austin so thats rwp
TyCZ28 is offline
Old 12-13-2011, 11:18 PM
  #32
Fondle's Avatar
these numbers are on a chassis dyno, and are wrhp numbers. NOT engine numbers
Fondle is offline
Old 12-15-2011, 11:50 AM
  #33
KC Henry's Avatar
Originally Posted by Fondle View Post
Well i just got my new 83lb injectors. and it should have came with a fuel pump i ordered also but it wasnt in the package so i got to figure out what happened to that
Turbo-Got for 50$ from a buddy
Intercooler and piping-250
Bov-105
Wastegate-320
3.5" and 2.5" stainless for hotside-180
Oil drain/feed-75
Misc.-100ish
So probably just over 1000 for the turbo parts.
Spent 400 on the motor
550 on 83lb injectors and a DW pump
240 on the brand new cam
300 for a set of 317's to be ported and milled for 9.3cr
What about the $1,000 Fast Intake & TB set up?
KC Henry is offline
Old 12-16-2011, 06:59 AM
  #34
Fondle's Avatar
i said 1000$ for turbo parts.. The fast intake setup has been on the car for like 4-5 years now
Fondle is offline
Old 12-16-2011, 07:14 AM
  #35
KC Henry's Avatar
I was just refering to the COMPLETE cost of the actual set up you are running, incase someone wanted to duplicate your build.
So all in all you have around $3,500 in the parts in the motor, including the cost of the engine it's self.
KC Henry is offline
Old 12-16-2011, 07:30 AM
  #36
Golf&GM's Avatar
Damn it, ok that's it I'm building a turbo 5.3. That's just stupid cheap for the power.
Golf&GM is offline
Old 12-16-2011, 11:39 AM
  #37
thehazz12's Avatar
I'm about to do one of these builds with my '81 Camaro. I won't be using any FAST products though...just an ls6 intake and cam. I may upgrade the tb though. I'm looking to push more than 6psi through mine though so theoretically I should be able to get more than 600hp to the wheels and that would be awesome!
thehazz12 is offline
Old 12-23-2011, 03:58 PM
  #38
Fondle's Avatar
Here is a few short clips in 2nd and third gear just getting into boost a little to hear my whistle ha. Nothing crazy or any 100% throttle pulls but here is an idea of what it sounds like with the cut open (3.5" downpipe open under the passenger seat with no muffler)
[youtube]http://www.youtube.com/watch?v=-RhIz4vojEE[/youtube]
Fondle is offline
Old 12-23-2011, 03:59 PM
  #39
Fondle's Avatar
[youtube]http://www.youtube.com/watch?v=ceb3mpvd9Ks[/youtube]
Fondle is offline
Old 12-29-2011, 09:05 AM
  #40
Awesome dude....I like how you showed the popo whats up at 1:10 in the first vid. Makes me want a 5.3 to replace my ls1
QIK E is offline
Quick Reply: Bone stock 5.3/ebay turbo/6psi
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
