going to the dyno, gonna get me alot of numbers :)
Well, I guess its time for me to post up in the big boys thread section
going to the dyno shop to day.
Speed Factory Direct here in El PAso texas
last "stockish" HP numers was 301RWHP/314RWTQ
For those of you that havnt been following my other then thread
heres the build. mind you this is all custom made. no sts parts where used in the making of this turbo build lol
INTAKE
3”x8” Cone filter tucked into wheel well
3” intake into turbo
2.5” charge piping
T-bolt clamps and reinforced silicon hose couplers
31x11x3 EMUSA bar and plate intercooler
50mm EMUSA BOV and pipe
LS6 intake manifold
80mm Throttle body
LS6 valley pan
4 port vacuum manifold
ENGINE
Stock 5.7L LS1
Stock 98 ls1 cam
Stock 98 ls1 Heads
EXHAUST
OBX stainless steel headers 1 ¾ primary, 3” collectors
Catless 3” ypipe with 3” OBX resonators
Stock I-pipe
Sts style T4 header pipe with 44mm wastegate port
3” after turbo resonator
2” Wastegate dump exhaust
3” turbine exhaust
4” corsa clone tips/3” inlets
Exhaust wrap from turbo back to headers
TURBO SPECIFIC
ON3 T76 w/.96 AR
Compressor Wheel - 76mm /.80 ar / 4” Inlet and 2.5”
Compressor Outlet - Inducer- 76.71mm / Exducer- 102.36mm
Exhaust Housing - T-4 Flange .96 ar / 3.0" Vband outlet
Exhaust housing - Inducer- 74.5mm / Exducer- 65mm
44MM wastegate 10psi spring
NXS manual boost controller
AEM water/Meth kit
will be tuned for 14ish PSI but will be limited to 10psi
TRANSMISSION
Stock 4L60E
Revmax stage 5 billet cover 3200 stall
B&M tran cooler
Glowshift trans temp gauge
OIL SYSTEM
4an feed
4an Summit check valve
.045 restrictor feed flange
10an drain
Gear scavenger oil pump
10an return line into oil pan
PCV system
LS6 valley pan with PCV valve
Catch can
Check valve
Vent line ran to fresh air intake tube from valve cover
FUEL SYSTEM
Stock fuel rails
Racetronix 225 fuel pump and harness
Aeromotive boost referenced fuel pressure regulator with 3/8 line return
60lbs siemens injector
ELECTICAL
NGK Spark Plugs BKR7E-11 5791 gapped at .032
MSD wires
Stock coils
ENGINE MANAGEMENT / MONITORING
Innovate MTX-L wideband
Glowshift digital boost/vac gauge
Glowshift digital fuel pressure gauge
GM 2 bar MAP sensor
IAT sensor in charge pipe.
MISC ITEMS
GM 93-97 radiator cover
Glowshift 3 gauge a-pillar pod
right now im seeing 5psi until i up the pressue on the boost controller
im hoping for a solid 500RWHP but ill take more its an automatic so i know its gonna read on the low side.
any guesstamates on what ill get today?
INTAKE
2.5” charge piping
LS6 intake manifold
80mm Throttle body
LS6 valley pan
ENGINE
Stock 5.7L LS1
Stock 98 ls1 cam
Stock 98 ls1 Heads
EXHAUST
Stock I-pipe
3” turbine exhaust
TURBO SPECIFIC
ON3 T76 w/.96 AR
AEM water/Meth kit
TRANSMISSION
Stock 4L60E
B&M tran cooler
OIL SYSTEM
4an feed
10an drain
PCV system
Catch can
Check valve
FUEL SYSTEM
Stock fuel rails
ELECTICAL
MSD wires
Stock coils
GM 2 bar MAP sensor
MISC ITEMS
How long do you hope the trans is gonna last?
? yeah im in the same boat, how would the stock 2.73 longer gears hurt the tranny more compared to somthing like 3.73 or even 4.10s?
ill tell ya, i dont even know really anymore how much its cost me lol the turbo build up alone is about $5-6000. I also got a bunch of suspention mods and little odds and ends. so after paying $10,000 for the car itself, im probalby sitting at about $20,000 total with mods and car payment
not too bad i guess when i got alot of it form ebay. some guys im sure have spent WAY more then that when the cars where brand new lol like the $30,000 price tag these car use to fetch back in the day off the show room floor in the earily 2000's
ok, learned somthing new today.
now to figure out why my car still isnt boosting past 5psi.
on one run run with the MBC set to almost lowest setting, got a 345RWHP run with about 3ish psi
couldnt get anything more then 5psi even with the MBC fully screwed in and actually started loosing boost when i did that. it actually worked better with the MBC on the lowest setting. with out the controller, i cant even get 1psi :/ so back to hunting down leaks.... waste of a day at the dyno
damn boost leaks. back to hunting down leaks.
Whats confusing about it?
Well, short gears on a bike would be the smallest sprocket on the pedal assembly and the largest sprocket on the wheel assembly. The longest gears are going to be the largest sprocket on the pedal assembly and the smallest sprocket on the wheel assembly.
they are close and at the time they were the only tuning shop i knew of. since i bought the HPtuner credits there, im kinda stuck unless i pay for another set of credits for another tuner.
yeah i happened on their shop by accident. they deal mostly with imports as oyu can imagine around these parts lol but they have done a few ls vehilces here and there from what i gather on their FB page. other then being a little pricey, at least to me, they are pretty decent. Rich, the actual tuner is hard to gauge, but Paul the front desk guy is pretty cool.
