Broken? Ly6 with tsp 231/236 256hp@5300 rpm
Well after fighting many noob battles. I went to dyno my truck
6.0
Ls3 heads
Tsp231/236 cam
4l80e with restalled factory converter 28-3200 ( was only looking for 2800)
3.08 gears
Truck dynod at 256hp @ 5300 267.45 tq rpm and started to fall off at 5300
Tr6 gapped at .40
I have headers (schnoenfelds ) i think 1 7/8 with dyno max ultraflows 3" all way no tail pipes.
Factory cai ( parts didnt arrive for cai. yes i know but 200 hp short)
I think converters broke because it wont do a burnout at all but any body else got stuff to check.
Doing compression check 1st. I did 2 cyls after 1st startup i was at 175psi. Im re doing all to see.
Any other suggestions?
6.0
Ls3 heads
Tsp231/236 cam
3.08 gears
Tr6 gapped at .40
They are the .650 springs that came with the cam kit from tsp.
trying to post graph but tuner beat me up about cam choice and swore it was the problem.
recommeded this
COMPETITION CAMS 54-470-11
GM LS LSR CAM -285LRRHR13
Specifications
RPM Range: 2200-7200
Lobe Separation 113
Intake Centerline: 109
Duration: Intake 285 Exhaust 301
Duration @
.050" Lift: Intake 235 Exhaust 251
Valve Lift: Intake 0.621" Exhaust 0.624"
HYDRAULIC ROLLER-Very strong from mid-range to high end torque and horsepower for LS engines with rectangular port cylinder heads.
Notes:
recommeded this
Specifications
Lobe Separation 113
Duration @
Notes:
working on gear and unit now. took to tuner because with the mail order tune it wouldnt run at all in drive. it would idle and fould plugs but that was about it.
thinking 4.56 because i plan on runnng a 31"+ tire on back. i was expecting much more even with what i brought to the table for now. heads are cnc ported and.
can all that be converter or should i be lookng at valvetrain still. incorrect pushrods or ?
took to tuner because with the mail order tune it wouldn't run at all in drive. it would idle and fould plugs but that was about it.
Dynojet i mailed whole computer to texas speed. Dont have a copy of tune now either tuner did it while i waited on the dyno. Pic upload keeps saying failed. Ill try again today
Valve or ignition issues? What and how do i need to check? According to tsp only need 2500+ Stall but i am in need of one since my intown restaller did not work out so well
Engine is 6.0 block forged flattops no valve releifs. Its getting gear too. Waiting on income tax for install already got ring and pinion. i tuned 1st because its hard to move around when it cant go anywhere in drive
My buddy dinnut said same thing about waves in the graph. Improper preload or ??
So other than a compression check on all cyl what else would yall like to see? Should i pull out all the pushrods and restart that process? Any suggestions. I may be able to get spring pressure tester from a buddy
Ok back from the dead... Went to the track with Circle D 3600 and 4.10s .. Only 1 pass due to no helmet 8.19 1/8th @ 85mph. Going back for a retune saturday morn after Ls7 maf and 4"Cai install. What are yall expecting to see new numbers
