Dyno results; LQ4/4L80, D1SC, FMIC, ect "6/05/15 UPDATED with track results"!
Well the second and final round of mods included a change from speed engineering 1 3/4 headers to their newest design of 1 7/8 headers. I went with a TNT hybrid 8.8 rear with 3.73's for peace of mind on hard launches vs the old 3.23 10 bolt I had on the 1st dyno and track visit. I also added an alky control single M15 nozzle setup running 100% M1 to the mix as well as swapping from the 4.5" pulley to a 4.25". This netted an increase in boost to 12.6# at redline. The dyno #'s weren't what I had hoped but they never are. It went from 556/504 to 603/519 on the same dyno as before. I will admit that peak torque dosent tell the true story here as it was sometimes as much as 45 or so more towards the top of the run. The track results were 10.55 @ 128.96 w/ a 1.683 60', a 10.683 @ 131.68 w/ a 1.720 60'. 1/8th mile speed was 104/105 on both runs. Timming was kept at 15 deg since more boost was added with the meth. DK if it should have been higher but its supposedly still safe for the stock LQ4 short block Im running. I know the 60' sucks but other than that, thoughts?
D/K... Dyno speed tuned it this time also. its still @ 15degrees timming @ WOT. I would have thought it could handle more but they said the extra 2# of boost required it to stay there? Maybe they are just being safe knowing Im not a track only racer and its my fun toy for driving around. Im also on a stock bottom end 2007 model LQ4 engine thats about a 10.2:1 compression ratio on 93 pump gas.
They just want to keep things on the safe side. I'm gonna mix race gas in mine once the forged short block gets here and let it eat. I made 10lbs at 5700 rpm. My blower is maxed out. I only have 12 degrees of timing in mine, but i was in the process of tuning it still.
The slowest pass was 128.xx and the fastest was 131.xx . The 1/8 mph was 104.xxx to 105.xx . I still think its flattening out on top because all the speed it picked up was 5mph in the 1/8th and 4mph in the 1/4 over my previous times before meth, more boost, and bigger headers. I did go from a 10 bolt with 3.23's to an 8.8 w 3.73's. IDK if the gear change is the reason for not getting more mph gain in the 1/4 than the 1/8 or not?
#34
Nice setup you have also. What kind of times or hp does it make.
#35
Thanks, Its definitely fun to drive on the streets. The 315 Mickeys can be manageable if you dont roll into too aggressively before about 40mph or so. After that it just rockets down the road with authority. With the cutout open @ WOT it screams like an old school big block!!! The only delima is now that I old enough to afford to build the car I always wanted in my late teens Im alot older with a wife n kids. I wont let myself do alot on the streets because of other drivers safety and the police are patroling every where now.
That's the fun it's all about , right.
This project is not doing as well as expected putting down 540/440 @ 6psi.
Track times don't impress either right now 11.4@120 1.6 60 ft.
But it gets lots of looks and thumbs up and puts a huge grin on my face still.
Hoping this spring will bring better results .
#37
F1a is pushing it on stock internals.
A boost friendly short block will get a much smaller pulley to go with it.
I also was looking for a stepped header to replace these 1 3/4 SLP's currently on the car.
I really want to be bottom 10's with the car , I don't know too many people that wouldn't smile tooling around town in that.
#38
Nice torque numbers bud.
Id be happy with bottom 10's as well.
