6.0, ported 243s, fast setup w/supporting mods.. 356 hp?
#81
So it basically made the exact same HP and TQ as the OP's car with a 6.0, bigger cam, ported Patriot heads, and a FAST 92/92 setup? You need to order that decal for the dyno Kent. It's a true Heartbreaker.
Do you have the graph? Does it look similar to the graph I sent you from when my car was on that other dyno?
#82
If you go to a better intake/tb setup you will get up on me for sure. I'm curious to see the difference in headers, I don't think it will be that much until you switch out that intake manifold.
Also your car is low as ****!
#83
Yea, my car made basically the same power as you, I think your heads are really good.
I'm going to raise the care up some. It's sitting on Viking 4 corner coilovers, so I can adjust the ride height pretty easily.
#91
Moderator
Received 1,835 Likes
So it basically made the exact same HP and TQ as the OP's car with a 6.0, bigger cam, ported Patriot heads, and a FAST 92/92 setup? You need to order that decal for the dyno Kent. It's a true Heartbreaker. Do you have the graph? Does it look similar to the graph I sent you from when my car was on that other dyno?
#93
Moderator
I still really love your car
#97
I went for the SE 1 7/8" for the price. I think I lost a little bottom (from the seat of the pants stab). I know, I know all that will argue...just my opinion. I will say that it now carries like crazy on motor and nitrous. I still have a LS6 intake and 241 heads Had my best 60' last Sunday in 85 S. FL heat BTW, 1.46...still haven't weighed this pig but it is full weight + roll bar, SFC, S60 rear, etc.
#98
If it couldn't make any more power up top, with the new headers, I would ,at least, hope the top end to be close to the same as it was.
#100
Do you think it could be something else causing the power loss? Losing fuel pressure, weak valve springs? I would try & make sure of this first.
It seems you were on the right track with the mid range tq increase. Then losing upper rpm hp seems odd. Do you think it has to do with the different brand of header? The SW headers are over $1k more than the SE headers new. There is probably a good reason. I don't think I could expect too much from the $280 set of budget headers.
