403ci Ls2 Nitrous Build Dyno Results (NA) 1 Attachment(s) Finally got the car on the dyno after sorting out spark issues. Ended up swapping over to the D585 truck coils along with br7ef plugs to get the car dialed in on the motor. Spent about 2 hours on the dyno getting the AFR to be correct and I am pretty happy with the end results considering its a dedicated nitrous build with a super tight 3400 converter. The injector duty cycle was at 102% with the FAST 36lb injectors so I just swapped in some Siemens Deka 60lbers. https://cimg3.ibsrv.net/gimg/ls1tech...931d9f292.jpeg DYNO SHEET ATTACHED As far as the torque being so low for a stroker I would imagine its due to the valve events of the nitrous cam opening the exhaust valve extra early. It wont be a record setter on the motor but when we hit it with the 300-400 shot it should really shine. 483WHP 405WTQ Looks like Ill spin it up to 7k for shifts. Below are the build specs: Bottom End 2005 Ls2 Block (honed .005" over) Precision Engine Parts forged 4" crank-24x Precision Engine Parts forged H-beam rods King Race main&rod bearings ARP 2000 Rod bolts ARP main studs Wiseco -8cc 4.005" pistons Upgraded tool steel pins Steel top ring/nappier second (.028/.030 ring gaps for heavy nitrous) GM Ls2 head gaskets Powerbond balancer Turn one power steering pump w/pulley 11.2:1 compression Valve-train BTR stroker nitrous cam (251/266 .632"/.596" 112+4) BTR Platinum .660" springs BTR titanium retainers BTR seals/locators/locks BTR Trunion rockers Morel 5315 lifters LS2 trays Manton 11/32 push rods GM timing gear/cam sprocket with ARP bolts New HD GM Timing chain with dampener Melling oil pump Improved Racing pickup girdle (awesome product) NGK -9 plugs Top End Advanced Inductions 226cc (243) heads (resurfaced for the swap) 63cc chambers FAST 36lb injectors Edelbrock Pro Flo manifold Edelbrock 90mm TB PCV delete with catch can Speed Engineering 1 7/8 headers TSP ORY with cutout |
Did you make a pull without that janky little air filter? |
Originally Posted by blk00ss
(Post 19219702)
Very nice 455GTO. Like you said, very purpose built nitrous motor. |
What intake Mani is that? And what all did you have to cut to make it fit? |
Originally Posted by Mavn
(Post 19220377)
What intake Mani is that? And what all did you have to cut to make it fit? As for the hood, there is the center piece that bulges out and had to cut that entire piece. Its a 2 piece construction so its only the underside of the hood that was cut. |
with that cam and setup i think you will see more with a supervic and 4150tb |
© 2024 MH Sub I, LLC dba Internet Brands
