5.3 MS3 prc2.5 dyno results
Have a fresh stock bottom end lm7 ms3 cam. Prc2.5 5.3 heads, kooks 1 7/8 long tubes. Bbk ssi intake. Th400 with 3.55 rear gear.
Car made 325whp@6300 rpm 295tq
Does this seem low? Should i still be making power at higher rpm?
Id post the graph, but have trouble posting pics here.
Probably low timing and not taking the car high enough in the RPM's, with a cam that large in a 5.3 your gonna be revving to 7k without a problem. Way too much cam unless you have an intended use for it, like racing.
It is pretty much a dedicated drag car that gets a good amount of spray. Tuner said i was at 27 degrees for timing
Thats what i thought. Turns out i have a bad map sensor code p0106. Not sure if that is affecting power output.
You need to rev at least 1k rpms higher, maybe more, and sort out that issue and retune. Bad MAP sensor will hurt you. That engine will not make a ton of torque but should wail like a banshee. That TH400 is going to hurt you hitting a dyno number too. What kind of car and rear end?
Ah, beefy rear and beefy trans are for track runners, not dyno queens. You're gonna have 20% driveline loss, maybe a tad more. Combine that with your tuning headaches and screaming powerband, I think that solves it. Get your tune right, run it a bit past 7k, do the math on the losses, and I think you'll be in the ballpark you're expecting. Regardless, and you know this, the ET and trap speed are your story here.
