Dyno confirmed on 6/3... results are in on Huron Single kit!
Getting ready to hit the dyno again (4th time with turbo setup)... made some modifications over the winter:
removed wastegate dump from downpipe to atmosphere
removed airfilter in lieu of a screen
added twin cutouts on my 2.5" dual exhaust just after where the single 3" DP splits
Aluminum DS
Street Slayer Twin Disc
Here is a rundown of the car:
2010 Camaro SS M6
Stock bottom end
AI 280cc Heads
Vengeance racing turbo cam (235/231 .6xx/.6xx 115lsa)
Ported LS3 Intake
NW102 TB
1000CC Injectors/ZL1 pump/ADM FPCM
Huron Speed single turbo kit with Precision 7675CEA
Alky Control w/100% meth
SLP under drive pulley
No cats
borla ATAK 2.5" exhaust
Tune via hptuners (me tuning)
going to be dialing in for 3 settings:
Wastegate - 8psi
Setting A - 16psi
Setting B - 12psi
Numbers will be on a dynojet and running 93 + 100% meth
I'll post my predicitions once people starting posting theirs.
Aluminum DS
2010 Camaro SS M6
Stock bottom end
AI 280cc Heads
Ported LS3 Intake
NW102 TB
No cats
Wastegate - 8psi
Setting A - 16psi
Setting B - 12psi
Decent day today. Had lots of issues, one being clutch slippage in the mid range, some break up in the high rpms, my cutouts stuck open, and I couldn't run under 13psi.
In the end, I made 817rwhp/758rwtq @16psi. I feel like it would have hit 850rwhp with no changes if it wasn't breaking up in the higher rpms.
So, even with the issues, I made 114rwhp more with the changes I made.
No knock... maybe spark issue, valvetrain issues? I dunno.
INjectors at 64% DC.
Moderator
Received 1,835 Likes
Thanks guys. One thing I just looked at... Plotting boost vs rpm, and comparing last time at 16psi vs this time... boost was lazy today and didnt hit 16psi until the end of the run. I wonder if my boost controller is taking a dump.
BTR .660 springs setup by AI for 15psi. The dyno tech said valvetrain too... but I got 1000 miles on this valvetrain. I'll pull the covers and take take a peak.
Moderator
I'm sure the springs are fine then. How about the pushrods, what diameter?
The clutch was slipping on the dyno... a couple runs were aborted half way thru because the revs jumped fast. Supposedly the tires werent spinning, so i don't know. It's a street slayer billet twin (so a rps clutch setup). I wonder is boost was lazy because of that.
