16' Camaro Ported H/C/IM/TB Bolt on's gains 189/111rw.
I haven't been on here in quite a while. I thought I would post this up though. Car is a 2SS A8.
I have been working my way methodically through this car seeing what gains could be made. I started with porting my stock IM/TB, then a CAI, then E85, headers, and finally a converter. Car ran 11.07 before the headers and converter. I then ported my heads with great results. The final step was to design a custom cam. I finally got it on the dyno today for some tweaking. I am running into some tq management issues that are limiting my power right now. I also didn't get to mess with my injector timing putting it more back towards stock to see if that was worth anything. Any way,
This first graph is Stock vs. Bolt on, heads, converter vs. all in with the cam.
Next is the gains from just the cam vs. bolt ons/Heads. 75/23rw for a cam in the 220's/230's isn't bad at all.
And lastly, just a solo pass all in.
How so? The stock motor is set up around TQ. It has a small cam with a ton of DCR and the VVT is what carries it out up top. So you get huge tq down low and about the same hp up top. In A8 cars the hp is always about 10rw less than the tq numbers. It is almost impossible to get back to stock DCR when putting a cam in a car. This isn't your LS. The LT1 is an entire new animal. Most LS cars tq doesn't pick up much from stock on the tq side of things when going cam only. With heads and bolt ons they will make more tq but the curves will look a lot alike. Almost every LT cam car loses tq to the stock graph or what ever state you started from. Mine is up from hit to quit over the stock graph. Actually, mine is up a lot all over. However, with the cam I am down a little below 3,300 from all Bolton's and heads. So I am not exactly sure what you are seeing or missing here? Head over to the dedicated Gen 6 forum and check out all the stock graphs you want. This engine is designed around tq. It is very hard to beat what GM came up with in that department.
Very impressive results Pray! Makes great power.
I'm not sure what you mean with "most LS cars tq doesn't pick up much from stock".
My stock LS1 put just over 300lb/ft down. Then after H/C/I it was over 400lb/ft. Just the bolt ons unlocked around 40lb/ft+.
Moderator
Received 1,835 Likes
+1. While i'll agree the LS generally gains more in HP than in peak TQ (mainly due to allowing it to breathe at the top end and rev further), I'm also 100+ higher than stock torque on heads/cam SBE LS1. I've similarly seen LS1's and 6's gain 40+ just from bolt ons.
I was thinking of another post I made on another site with just the cam gains. My comments were about just the cam gains. I went back and edited my above post.
Let me rephrase what I was trying to say about the differences between the motors. Due to the advantages of the LT1 it is much harder to see gains in tq than over an LS. So saying the tq curve that is way up from hit to quit looks like "****" makes no sense to me. You will not see the same shape in the graph's in an LT car once you change the heads or cam. The stock low end is extremely hard to beat. When I ported my heads I only gained 10rwtq but 28rwhp and it changed the curve. I gained about 12rw down low with the cam and it blew up the top end. The stock IM also makes a ton more tq than the MSD. I may throw my ported stock IM back on the car to see what that does to the top end and the curve. So there are many things in this equation that have changed the shape or the curve from stock. They two biggest contributing factors are the ported MSD and the cam. The heads play a bit into that as well.
I am also running into a wall with the TM and TQ Coefficient tables that I feel is limiting me some. I usually gain 23-25rw going from 5th to 6th gear on the dyno. However, yesterday, I was seeing 547rw in 5th and I was staying above my tq boundaries only down low and was coming back under them up high. In 6th I was above the boundaries all the way and I didn't see my normal 6th gear bump in hp/tq.
This cam is also only high 220's/mid 230's. I don't think I have seen another H/C SBE Gen 6 make more power or tq. I know I haven't seen any make the gains from stock to where mine is at now, especially not an A8 car with a converter.
ive been out of the game for a long time and have no experience with these LT1's but you are making nearly 600rwhp with stock bottom end and no power adder? that's incredible...
Car is basically putting down what my 427 Gen 1 V did. Technology is a pretty great thing.
Yes, just H/C/bolt ons. And a lot of porting LOL. I have identified some issues that are holding back my power numbers right now. A couple I hope to rectify soon. The main one though I may have to pull the car back apart for. I am shooting for 575rw all in.
Possibly in an M6 and on a different dyno. This dyno is a bit stingy as you can see from the stock numbers. But the car always runs faster than the dyno says it should so I am cool with that. I have an M6 build coming out next week with my STG I cam on a totally different dyno in another part of the country. Depending on that one makes we will be able to make some judgement calls on where mine would be.
Youre missing what I am saying. The torque curve looks completely different on the graoh showing all three runs vs just the single run. The max power curve is what I'm talking about. It looks like it changed. Maybe it's my eyes or brain, but something looks off. I'm not insulting anything, I complimented you, jesus christ sally.
If you can pull up the cam vs. no cam the tq lines over lap at a couple places and look deceiving. I tried changing the colors of the lines but they still cam out pretty thin. The cam is down on tq from 2,600 to 3,300. Then it passes the no cam. The no cam catches back up right at 4,500 due to the shift in the curve up 750rpm with the cam. The early loss I am sure is due to me not having enough head room in my Commanded TQ vs. my Allowed TQ and TQ Coefficient tables. I have to work on those a bit more to allow the car to transfer all the power I want to the tires.
