434ci, MMS 265 heads, Super Victor intake, MMS solid roller cam - dyno results
How hot does the tranny and rear end get after running for 25 minutes?
Nosey noob....
Nosey noob....
Unfortunately I don't have a good way to know. I don't have temp gauges for the trans or diff. Just engine oil... I can only judge it based on the fact that shifts stay consistent and I haven't seen any wear or noise from the diff, not excessive metal in the oil.
Those are likely fair indicators.... And as long as you have run that car, have there been any catastrophic failures of tranny or rear end? If not, you are doing something right!
I did something I haven't done before as part of this installation. I went through a full alignment of the bellhousing. There are different recommended procedures for doing this, probably the most accurate being to pull the front cover of the T56 to do it. I didn't go that far but instead purchased the alignment plate from QuickTime which bolts to the bellhousing. I measured the parallel surface and used shims to adjust, then the concentric alignment. I used some 0.007" offset dowels to get it as close as I could. I've never had shifting problems before, but since this is a new-to-me block, I wanted to check it all out.
Engine and transmission went into the car today. Still a long way to go and several challenges to overcome, but at least it's bolted into place...
Awesome results....thanks for posting this. I'll be doing something similar soon but with an LSX 427in short block with Tony's 6-bolt LS7 heads, YT rockers and cam. I'll also be running a single plane intake. I don't think the Mast intake or any intake porting are in the budget this time around so I'll be running an out-of-the-box stock Super Vic. But it was really cool to see your back to back comparison of the intakes.
Anyway, I saw you said you'll be running 1 7/8 headers in the car. What size headers were on the motor when it was dyno'd? It looks like they may have been some kind of stepped design. I assume they were dyno header from SAM?
Good luck with your build as well!
If you buy the Super Vic, assemble the fuel rails and injectors and ensure you have a good seat before you do anything else with it. As I noted, the bolt holes in the intake were drilled and tapped at an angle which caused the rail to sit too high. We slotted the holes in the rails to bring them down, and that should be ok for me. It's a pain to have to do this though on a brand new item.
Perfect, thanks. I was going by your dyno pic but I was looking at it on my phone. The tubes looked like they could have been stepped but it's hard to tell on such a small screen. I look forward to seeing how your rear wheel dyno numbers compare to your flywheel number. Very cool car!
Cool. I cain't wait for another build Gary.
The engine and transmission are in. Last weekend I worked to get the exhaust (headers) bolted on and new oil lines made. The car is going to have to go to my fabricators for some work before she'll be driveable, so it will be a while before I have chassic dyno results unfortunately...
I'll certainly update here when I do!
#32
It's taken quite a while to get to this point, but last weekend I was able to start the engine in the car for the first time. This video was after I had it warmed up, but I've done basically no tuning yet, just using the baseline I had on the previous engine combination with the upper RPM tuning from the dyno session. Tuning from Lorenz in the previous post.
It's not a dyno run, so don't get too excited, but after 13 months of sitting, it felt damn good to me! I love this sound!
https://photos.app.goo.gl/UjFhbao6vqLl1A2I2
(no idea how to embed it)
#34
Awesome Bryan! I have been wondering about this build.
#36
#37
What exhaust is on this beast? I think* I may of asked this before, I don't recall. LOL
#38
The exhaust is all custom built tubing. 3" round off the headers transitioning to 3" oval to get better ground clearance under the middle of the car, back to 3" round into the drive shaft tunner. Borla Pro-XS mufflers (3" in and out), then 3" round tube over the axle and out the back.
It's a challenge to snake that 3" tube up and around the axle with a Watt's link in there...
#39
Carbuf,
Thanks!
Thanks!
#40
