427 Small bore engine w/ MMS 260 LS3 Heads
#41
Moderator
Received 1,835 Likes
Your rpm is way out of range for a stock ls3 intake.
#42
The only thing I'm worried about with these runners would be a worse 60'. It will make more peak hp. As long as the et is better overall its going on. I should order one anyway. I can even try It on my ls3 vette. I pulled the trigger on a yank for it so it's going to be nipping at the 10's soon The mids might even help that car get there with a stall/boltons. If it works it's 10's with the top down and another one for the stroker. If the vette doesn't like those runners I'll get a stock fast with the big runners and I'll have two ls3 intakes to sell. Sold an extra Z06 Npp I had lying around on the forum today that helps.
I guess if the mids are that good on the strokers somebody is going to half to try the shorty's. Every dyno queen should have those red shorty's. lol.
#43
#45
Location: Coast of San Mateo County Between Pacifica & HMB
Curious if you ever installed on your Stroker and/or Vette?
Also thought LS3 Stroker guys running Ported OE Intakes or Standard-Length FAST Runners should see
data if they haven't.
