Full Mamo H/C/I build on low mile C5 Zo6 with dyno results
I picked it up Thursday a d have to say, it rips. The power really comes in strong around 3k and feels like it would keep pulling to 10k if you wanted it to. Driveability is great, but the clutch already locked me out after a 1-3 pull. Haven't felt it slip per se but I'm already ordering a clutch. I'm probably doing the LT1s because I'm a fan of the oem style clutches. I just don't think any of the real aftermarket stuff can compare for driveability.
Location: Coast of San Mateo County Between Pacifica & HMB
The Drivability of the MMS RPS BCII Lightened with the steel flywheel
is really close to stock. Unless you are daily driving the hills & streets
of San Francisco (LOL) you are doing your Z06 & Mamo Top End a
disservice and it would likely be the last clutch you would ever need,
they wear like Iron (ask Darth) and they are rebuildable. I had one
on my SBE to get used to it/break it in before my 396" install in my
99 C5. The revability/throttle response on my SBE was noticeable.
Moderator
Received 1,835 Likes
11/16 master (0.700") makes those hydraulics feel like buttah
Picked up an RPS BC2, and all should be well in the clutch dept.
how's the noise with the mamo clutch? did it add any bucking or other drivability issues being that it's significantly lighter than stock? My understanding is that this is a typical trade off with lighter clutches.
#34
I'm hoping that by keeping the fast and 102 tb the car will still be very responsive and retain all the great things about the n/a build. Also hoping that itll help retain the awesome flat power curve it had. Plus not to sound like a loser it looks better too.
#36
Early Fasts didnt have great luck but that's changed. Hoping only 6-7 psi wont be a problem but we will see. I still have all of my stock parts should I have issues. I can only imagine the ported fast will have some power gains throughout the rpm range over an ls6.
#38
yea I hear ya, I was in the boat that I already had it so it wasnt anything extra for me. I'm pushing the limits of the pistons anyways so if I can make the most power on the least amount of boost I think it's a better plan. When I do a shortblock I will likely go back to the stock ls6 intake.
#39
