Bolt-on A4 01 Z28
Bolt-on A4 01 Z28
Power Mods:
Yank ss3600
Kooks 1 7/8'' LTs
Kooks X
Kooks 3'' TDs back to quad tips
Chris1313 ram air w/ AC version
FTP 98mm lid
Truck MAF
Home-ported stock TB
Plugs & wires
Lingenfelter 180 degree t-stat
Richmond 3:73s
Mike Norris tune
Other Mods:
BMR suspension(no tubular k)
Aluminum driveshaft
TA girdle
Poly motor mounts
New brakes/rotors
C5 18'' wheels
Nitto G2 summer tires
Car dynoed 348rwhp/361rwtq on a dynojet with the stall locked
This car is going to be my summer "nice day" daily. Overall, I am very pleased with the cars power & the way it puts it to the ground. I would like to thank Mike Norris for getting me in for the tune. Mike is a well-respected LSX tuner & Tech sponsor(I believe) but he does it all. While picking his brain, Mike told me the highest hp bolt-on LS1 to cross his dyno was a M6 car similar mods to my A4 in addition to a Fast 92/92 setup and crank pulley. It put down 365rwhp. I just say that because all dynos are a little different & I wanted to reference that for myself and you guys.
Future plans for the car right now are just a BMR tubular k-member and a ATI balancer. Other than that I am pretty much done putting more money in it for a while. Thanks for reading and let me know what you guys think!
The final dyno pull.
Here is the graph and some car pics:
Yank ss3600
Kooks 1 7/8'' LTs
Kooks X
FTP 98mm lid
Truck MAF
Plugs & wires
Richmond 3:73s
Mike Norris tune
Other Mods:
Aluminum driveshaft
TA girdle
Poly motor mounts
New brakes/rotors
C5 18'' wheels
Thanks! It feels really strong most likely due to only having 70k on the clock. I may not make it out to the track until next spring or fall even tho we have a nice local quarter mile track. Like I said I plan on it being a nice daily but when I do hit the track hoping for a 11.9x pass with a tubular k, crank pulley, & better tire.
Agreed. For that kind of pass do you think I'm looking at a minimum of 1.7-1.75 60' with about a 112-113 trap needed? That's kind of my assumption with everything I have read.
Nice numbers OP! Like what was said above a lite wheel and soft tire with good air will probably get you a 11.9 your looking for.There's still a lot of bolt ons you could do as well. Just depends on how far you want to take it.
Thanks! Yes, the old LS1 is still very effective with todays aftermarket for them. The goal all along has been for my car to be competitive for the newer stuff coming out with my motor still having its factory seal.
Yeah I would assume the stall wasn't locked. The dyno could've also been a lower reading dyno. Maybe both. 300rwhp stock tho is good!
Actually the dyno turns out very typical numbers for a dynojet dyno, but from 300 bone stock to 325 with full bolts and stall on the same dyno was a bit surprising. Having it unlocked must make a huge difference
Thanks! We'll be close if not there with wheels and a good tire IMO!
Yeah everyone says the stall eats up dyno #s like crazy. That's why one of the first things I asked my tuner was will the stall be locked or unlocked. Because, I didn't want to look at the graph and feel instant disappointment lol he told me he always locks them.
