GM LS3 LS376/525 Crate Motor
#101
Honestly, it sounds like you need a tune, badly. I have the ASA cam in my 5.3L and it does not stink much at all. Some, but not crazy. Then again, I have spent A LOT of time tuning my idle (I have a Holley Dominator). With the Dominator (and all Holley systems) you can specify the injector end angle. This determines when the injector pulse ends relative to the valve events. I have it programmed so that at low RPM the fuel is sprayed a little later, which helps cut down on raw fuel exiting through the exhaust valve during overlap. I don't know if the stock ECU can do that.
It also drives perfectly, even when lugged down, and I get 21mpg (I realize I have a smaller engine) with 4.33 gears and a T56.
Andrew
Andrew
#102
Andrew
Andrew
#103
#104
I want to see what a tune will do. Maybe it will clean this up a bit, but my feeling is that, with the choppy idle, the low speed drivability, and the breathing impact (for all involved) this cam is coming out. CO aside, it doesn't cruise well, the bark of the cam isn't backed up by the bite, the unburnt fuel smell stinks, literally, and I'm running catalytics.
Your car will also know every gas station in town as it gets about 9-10 mpg. I'd rather have a stock GM LS3 cam.
We can try adjust injector angle, but I thought that would have been dialed in by GM.
Another key point is that the 430 on an engine dyno with the same accessories as the 525 actually puts out closer to 490, not 430. The 430 number is sand bagged, so GM can sell the 480 and the 525 for lots more profit with very similar manufacturing cost.
I had my 996 swap on the dyno twice. The first time the air at the intake was getting too hot so timing was retarded and car put out 290rwhp. After installing a fan in the deck lid temps came down and the engine produced 346rwhp on a clean pull. Since then we got the idle sorted so it doesn't hunt so much. The dyno was a Mustang, and the tuner knows his work. He tuned a Super light coupe with the same engine and transmission (manual 6 speed transaxle) though that car had a high end titanium exhaust. The SLC pulled 350, so basically extra 4 hp at the very top end revs. So my stock 911 cat delete exhaust is not the issue.
My conclusion at this time is the additional ~35hp of the 525 over the "430" is not worth the problems or the additional cost. GM's marketing is intentionally misleading. If you want more power, get a stock LS3 engine, reinforce the internals and add turbos as most modern engines do today. It won't improve the gas mileage but at least the fuel will actually be burnt, the car won't stink and it will have 600+ hp.... and lots more heat to deal with.
#106
The manufacturing costs of the 430, 480,and 525 are IDENTICAL. The ONLY difference in the 3 engines is the cam. And all cams cost the same to make. Just different grind profiles.
#107
Cam costs are not identical since the manufacturer of the Cam will price it based on volume. Fewer 525 cams means higher cost per part. Also 525 has different valve springs. Likely also some changeover costs on the line. So costs a bit more, hard to guess, maybe $100 to $200? Not $2k though.
Also, is that the only point worth commenting on?
#108
And on the GM scale of things, the 480 and 525 cams are run on the same production machinery as the rest of them, so cost per unit might be a tiny bit more due to the smaller numbers.
#109
According to the GM website.
The ASA camshaft is a hydraulic roller with .525-inch lift on both sides, along with 226 degrees duration on the intake side and 236 degrees on the exhaust side. And for durability, we complement the cam with higher-rate valve springs.
https://www.chevrolet.com/performanc...ines/ls376-525
Same for the DR525.
Same for the DR525.
#110
OK thank you. I don't think that was always so, but I could be wrong. Even with the low lift, the ASA ramps aren't the smoothest. GM had the same problem with the LS2 cam. Same lift as the Hot Cam and ASA cams (.525) but it would float the valves before 6200 RPM. So yeah, the high rate springs are a must.
#112
GM has the LS9, which is 211/230, .558/.562, 122.5 LSA that gets used a lot. With about a -25 degree overlap, it WILL pass smog. It normally goes on the LS9 supercharged engine.
Cam Motion's smallest LS3 cam is 212/222, .553/.553,116 LSA. Not positive it would pass smog, but with a pretty smooth idle it should. A -15 degree overlap SHOULD allow it to pass.
#114
PS. Thanks to all the contributors to this thread. Have learned quite a bit from everyone. Apologies for tone on some of my posts.
Heading back to the tuner to see of we can work with this cam to improve the emissions and the poor throttle modulation below 3k rpm. Running a stock GM 430 ECU, hopefully we' will have enough capability with it.
#115
#117
Thank you for this! I did not THINK the springs were different, but was in no position to argue. I agree with all you say here.
#118
#119
Like I said....it's a VERY recent change....like in the last 4 months.
That said, the price difference in the three crate motors is completely reflective of the HP of the engines.
It has nothing to do with higher rate springs and nothing to do with a higher cost cam.
BTW....the ASA cam costs LESS than the HOT cam.....and it always has.
https://www.gmperformancemotor.com/category/LS214.html
KW
KW
#120
KW
KW
Within the same mfr., a cam is a cam, whether for an LM7 truck engine or an ASA cam.
Same for springs, within reason. Wire winding is the same process whether for the above-mentioned truck engine or an LS3.
