Notices
520rwhp N/A stock bottom LS1....
Old 06-23-2018, 08:41 PM
How close to coil bind do you shim your springs?
G Atsma is offline
Old 06-23-2018, 09:37 PM
LSOHOLIC's Avatar
I'd need to go back and look at the notes....but..IIRC...0.040" sounds familiar .
Also taking into consideration the closed and open pressures at that height.
LSOHOLIC is offline
Old 06-24-2018, 12:14 AM
NSFW's Avatar
Did the 3/8 pushrods fit right in, or did you have to make clearance for them on the block or heads?
NSFW is offline
Old 06-24-2018, 09:02 AM
Omega Doom's Avatar
ok more tech questions...… what is the compression ratio? and this is just a Hydraulic roller correct? was it degreed? also what fuel pump are you running and what Dyno #s did you get on pump gas? and I know this this isn't your Daily but just for giggles what did you get mph wise just a guess lol
Omega Doom is offline
Old 06-24-2018, 09:08 AM
LSOHOLIC's Avatar
Yes, sir....3/8" dropped right in. Trend single piece tapered ends.
LSOHOLIC is offline
Old 06-24-2018, 09:20 AM
LSOHOLIC's Avatar
~Static is around 11.8:1-ish for the E (it was 11.3:1-ish when on pump 91oct)
~Yup, hydro roller
~Lined up dot to dot...let her eat
~Single Walbro E450
~Back when it was on pump 91oct and no vacuum pump....it did 500rwhp...but that was also a different cam
~You asked mph..I'm assuming you meant mpg ? If so, in 6th gear doing 75...it would get upper 20's per gallon. But remember, I'm on a MT 325's (28") in 6th gear...it was only turning 1700rpm.
LSOHOLIC is offline
Old 07-08-2018, 04:10 PM
Not to sound uneducated, but what causes vacuum at upper rpms? Seems like I heard the tuner say mine was pulling vacuum at wot
timothy_5326 is offline
Old 07-08-2018, 05:12 PM
Not enough intake capacity. The engine wants MORE!
G Atsma is offline
Old 07-31-2018, 06:32 PM
A.P.D.'s Avatar
... how much vacuum ? ...
A.P.D. is offline
Old 07-31-2018, 06:40 PM
Tuskyz28's Avatar
Brian Tooley strikes again
Tuskyz28 is offline
Quick Reply: 520rwhp N/A stock bottom LS1....
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
