Any 500 NA rwhp 6 speed combos?
#81
I have a 416 LS3 that I put together 3 yrs ago. It has GM CNC LS3 821 heads 68cc chambers hollowstem valves unmilled cometic .040 gaskets & a domed valve relief Wiseco piston 11.5:1 CR. I bought everything new. I went with a 6.2 block to run the square port heads & stock intake over some more expensive aftermarket heads & high dollar intake as the stock stuff works very well & is much cheaper. I've been very pleased with the performance
#82
custom cam by Martin Smallwood. 242/256 .629 .609 113+4 & was degreed I had a local machine shop put shortblock together I did the rest. I got a deal on the heads bought them nib in tech classifieds for $1100 shipped
#84
I've drove the car everywhere & 80+ miles to the track, peeled off 1.4 60s with 6500 rpm clutch dumps & drove it home every time. High 10s on motor 127-128 but has been 130 once on a very cool day. Made 513whp 482tq through TSP TDs. 20 mpg highway, can drive the car however ya want idle is a lil lopey & takes a few minutes to idle on its own but after that perfect!
#87
#91
5.7 block w/ 4.100 crank and 243's made 498/502tq
https://ls1tech.com/forums/dynamomet...yrs-later.html
ran high 10's @129mph n/a
low 10's @138mph on 120 shot
#92
https://youtu.be/FKbWORt1dkE
https://youtu.be/zkWe89w88Ak
#93
This was only a 10.60 pass on the 100 shot didn't look at controller screen had it on a 1 second delay. Also had launch controller set lower at 6k so that killed my 60 ft some (1.57 vs 1.43) Went 10.12 with no delay right after but nobody got a clip of that one. Tried uploading last week but here it is!
#98
You could always just pick up a used pullout LS7 (Corvetteforum.com) for around $7K... swap the cam to something more aggressive and easily make 500rwhp on 91 octane.
Cubic inches will make your goals waaaaay easier and increase longevity. The increased torque of a 416/427ci engine is no comparison to a 364/376ci engine.
