Notices
5.3 Twin S371s
Old 07-22-2018, 12:02 PM
Default 5.3 Twin S371s
Forged 5.3
LJMS TT Stage 1 cam(probably going bigger shortly)
TFS 220 Heads/CA625 head studs
Twin S371s
TH400/PTC Convertor/3.08 gears
417 Motorsports 2000hp Intercooler
Holley EFI/160lb injectors
E85/Cable Driven Fuel Pump
This was on 25lbs with pretty low timing had to cut it short had a leak with the A2W pump. I will do some more pulls shortly was planning on running this into the 12xx range which if it keeps up with current gains per PSI should be 32ish psi and then get it to the track.
mshadow is offline
Old 07-22-2018, 04:19 PM
dmracing's Avatar
Is that the 417 motorsports lower.
dmracing is offline
Old 07-23-2018, 08:16 AM
Yea it is
mshadow is offline
Old 07-23-2018, 08:52 AM
dmracing's Avatar
Do you have a hood that will clear that. If so how tall is it
dmracing is offline
Old 07-24-2018, 12:43 PM
Nobody really makes a cowl for a 4 eye that is high enough I was going to cut the feather lite hood I have or switch to a aero front end.
mshadow is offline
Old 07-24-2018, 04:45 PM
dmracing's Avatar
What the height of the highest part of you intake from the valley cover. If you don’t mind measuring.
dmracing is offline
Old 08-28-2018, 12:26 PM
Any updates on this?
roastin240 is offline
Old 08-30-2018, 02:11 PM
Hitting the track in the next couple weeks summer was busy.
mshadow is offline
Old 08-30-2018, 03:03 PM
dmracing's Avatar
Any way you could measure from the valley cover to the top of the intake for me?
dmracing is offline
Old 09-07-2018, 12:48 PM
Nice build. What cam? Peak power is low in the rpm band.
RealQuick is offline
Old 09-07-2018, 05:10 PM
LJMS TT Stage 1 Cam - 222/231 .602"/.598" 112+4 I had it kicking around from when I was going to do a SBE build.
I will probably change it out to something bigger at some point for more RPM
mshadow is offline
Old 09-08-2018, 10:27 AM
15 inches from valley to highest part of high ram where it peaks by TB
mshadow is offline
Quick Reply: 5.3 Twin S371s
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
