Ol 383 back on the rollers.
http://www.performance-world.com/Cyl...s-p/63240a.htm
Oh yeah, You know the bitching is coming..........E85!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!
Thanks Mike.
So just for fun I got the graph scaled on the 50hp as we usually do. Just to show the power does not drop as hard as the other graph skews. Actually my car's power does not seem to fall off at all up top. As I've noticed on a race vid. Where I expect to see my car fall off say after 6500rpm to 7100. It seems to pull strong, the strongest, up top until I shift.
I figured one thing that may have something to do with how it pulls like that & doesn't fall off as the power scale would imply. If you multiply the hp by the rpm it is at you get a number. My number peaking around 500rwhp at 6600rpm. The number is 3.3mil. Now multiplying anything after that all the way to 7200 rpm the number is right around the same 3.3mil. Is this a way to tell basically if it is an advantage or disadvantage to keep revving. Say if the number started getting below the 3.3mil that is when you will start to see the drop in performance?
Oh and the SAE number dropped 12hp to 492.
Look at torque at x RPM in first gear times first gear ratio. Then look at RPM where you land in second gear. Multiply that torque by second gear ratio. If total first gear torque is still higher than total second gear torque, you should stay in first.
With your power peaking at 6600, your shift point may be as high as 7600 rpm, land right on 5200, and ride the power curve.
There are people with your power curve who would shift at 6600 and lose 1000 ft lbs of actual rear tire torque on the upshift by the time you factor in transmission and rear gear ratios.
