How much power from this set up?
Guys, how much power do you think this setup will make?
AFR230 HEADS
FORGED LQ4
.040 HEAD GASKET
CUSTOM COMP 235/242 CAM
1 7/8 LONG TUBES
FAST 102
102 TB
85MM MAF
MANUAL CAR
Just trying to see what you guys with a similar set up are putting down.
AFR230 HEADS
FORGED LQ4
.040 HEAD GASKET
1 7/8 LONG TUBES
FAST 102
102 TB
85MM MAF
MANUAL CAR
Restricted User
Moderator
Received 1,835 Likes
430 with the maf 470 SD with a 4 inch CAI and true duals
GEt rid of that 85mm MAF
Moderator
I don't get the low ball numbers. This is a 6.0l. Not an ls1. Good heads, 23x/24x cam, 1 7/8 headers, fast 102, M6. My buddies h/c 6.0l, still on ls6 intake, y-pipe single exhaust out the back. Made close to 470rwhp. Of coarse all depending on rest of setup & dyno. Exhaust/induction. I'd guess about 450+.
Originally Posted by G Atsma
I think the low-balling is because some believe that the 85mm MAF is choking it.
