G5X3 cam and LG/AFR , 90mm intake/TB
Old 12-07-2004, 04:43 PM
LG Motorsports's Avatar
Default G5X3 cam and LG/AFR , 90mm intake/TB
Hi guys,
Well we just got a car off the dyno with our LG Cam and head package including our LG Pro Long Tube headers and all I can say is wow.
486rwhp 437 rwtq !!
The heads are AFR 205 heads that we upgrade the springs and compression to 11:1
We used our LG Pro Long Tube 1 3/4 headers and our G5X-3 cam on a 114.
The car is a daily driver and it runs great in traffic or highway. the normal G5X-3 manners.
The car also has a Fast 90mm intake and our LG/NW 90mm throttle body.
This is as driven on the street with stock waterpump with all belts on the car. I might take it to another shop to dyno just for fun. We have done that before just to show that our dyno reads correctly.
At any rate, here is the graph
4100 rpms to 6300rpms over 400 ft pounds of torque.
4800 up the power is above 400 hp
and at 5250 the power is almost 440rwhp all the way up to 6800
Nice package.
Car is a 2001 Corvette Z06 with Borla mufflers and full exhaust.
thanks
Lou Gigliotti LGM
Old 12-07-2004, 06:53 PM
Senior Member
Country Boy's Avatar
Damn it Lou... stop posting this stuff. It make s me want to rip my car apart
Old 12-07-2004, 07:13 PM
IntenseSS's Avatar
What about the g5x-4.........????
Old 12-07-2004, 07:37 PM
Camaro_Zach's Avatar
****** right!
Old 12-07-2004, 08:02 PM
apexman's Avatar
Now that is a heads and cam package! Nice torque al the way across! Not to mention horsepower. I bet that would scream on the street and at the roadcoarse.
Derek
Old 12-07-2004, 08:29 PM
LSX Mechanic
Damian's Avatar
That's a **** TON of TQ.
Lou, you guys need to put something something similar to this and tune it for a 150-200 shot. Those big split LG cams would make some serious power on the sauce.
Old 12-07-2004, 09:46 PM
WS-Sick's Avatar
Nice! So the AFR's are ported?
Old 12-07-2004, 09:59 PM
I8AFORD's Avatar
I think they are out of the box..they just change the springs and have them milled for more compression...
Old 12-07-2004, 10:40 PM
InsomZ's Avatar
Lou: hey do you have any track times from any z06's w/ that g5x3/afr head setup??
i know there are a few z06's rolling around w/ that seutp.. curious what trap speeds their getting.. J-rod is the only head/ g5x3 cammed zo6 i've seen times on.. pretty damn good times too!
Old 12-07-2004, 10:46 PM
WS-Sick's Avatar
Ah, yes, milled to get that CR. Thanks
Old 12-07-2004, 11:17 PM
Hi GUys,
The G5X-4 would be nice but this customer wanted to have a daily driver street car with muscle. He doesn't want to go to the drag strip. So we went with the G5X-3. Now here us talking about the G5X-3 as a mild cam??( oh, he wanted a daily driver)
The G5X-4 is for Country Boy's new G5X-4/ AFR package
The Ls1 edit has allowed all of the tuners out there to make the LSx engine run great even with pretty large cams.
Keep in mind that the G5X-3 cam goes right in a stock LSx engine without any flycutting.
J-Rod had the same cam but the heads were not up to the new AFR castings. Remember they started with a new casting so they could add meat in areas so they could raise the ports and vastly improve the flow.
The only 1/4 mile times were j-rod with similar numbers and heavily modded ls6 heads at a 10.6 @ 126 mph. And Maggie who ran 10.83 @ 126 with her F-body at 3450 race weight.
i am sure that there will be some who 1/4 mile the package.
We need some of the F-body crowd to step up to the plate and hit the package full force and take it to the strip.
thanks guys. We will be getting some AFR 225s for a stock cu in soon.
LG
Old 12-07-2004, 11:40 PM
black_z's Avatar
Nice numbers Lou.
Old 12-08-2004, 02:46 AM
I can shift faster than you.
Jason99T/A's Avatar
Very impressive Lou! Nice job!
Jason
Old 12-08-2004, 02:53 AM
2MuchRiceMakesMeSick's Avatar
Very nice number from a head and cam Z06
Old 12-08-2004, 06:28 PM
David Gordon's Avatar
Damn thats as good as my newest results from my 395 stroker. I just added the 90mm setup and I have race heads and a medium cam with TPIS headers and I think we did,
486 rwhp and 448 rwtq.
Old 12-08-2004, 06:33 PM
I8AFORD's Avatar
OK..I just may do that...But I have a X-2..how much HP will I be leaveing on the table? 10hp?
Old 12-08-2004, 06:54 PM
Squintz Palladoris's Avatar
I have the X3 114* in my F car. Will I need to flycut to use these heads?
Thanks!
Brad
Old 12-09-2004, 06:55 AM
Senior Member
LG
hehehe.......
Old 12-09-2004, 03:39 PM
Ravenous T\A's Avatar
Did you guys have to flycut the pistons with those heads??? Great Numbers
Old 12-18-2004, 01:51 PM
We do anyway, because we want to make sure that even with a missed shift from 3rd to 2nd instead of 3-4 shift, you won't tag the valves.
Thanks
Lou G
Quick Reply: G5X3 cam and LG/AFR , 90mm intake/TB
