1 3/4 vs 1 7/8 header dyno RESULTS!!!
Old 03-26-2005, 03:05 PM
383ss's Avatar
Default 1 3/4 vs 1 7/8 header dyno RESULTS!!!
this is on my 408, old headers were 1 3/4 dynatechs with open headers, 3" collectors, no extension at all. now it has Thunder 1 7/8 with high velocity 2.75" merge collectors and 17" extensions.
overall I'm suprised by the results. thought it would gain a little more hp up top. my shift points are definatly going to have to be 3-400 rpm higher now.
here's the graph.
Old 03-26-2005, 03:16 PM
LS1 Tech Administrator
Patrick G's Avatar
Wow, interesting results. Certainly not the big kick in the mid-range I was expecting. You may want to experiment with shorter extensions (like 10"). An 8" change in length can have a dramatic impact on peak torque and hp. I think there's tq. to be gained with either longer or shorter (my bet) extensions.
Thank you for reporting the results. We've been anxiously awaiting!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 03-26-2005, 08:26 PM
Jewmont3's Avatar
Looks like you just traded close to the same amount of torque for a similar gain in hp up top. Being a truck owner with the plan to drop an LS1 and T56 into it I deffinately would be looking for all the torque possible. Looking forward to any changes you might make for improvements. Thanks for being the ginea pig
-Mike
Old 03-26-2005, 10:03 PM
Got Me SOM's Avatar
i'd put the 1-3/4" back on.
Old 03-27-2005, 01:03 AM
Nate_Taufer's Avatar
Seems like the gains aren't worth the losses. I would also put the 1-3/4" back on.
Nate
Old 03-27-2005, 01:12 AM
02WS6Bird's Avatar
Not bad, as said before looks like a fair trade off. Excellent information and graph for comparison. I prefer the torque however, maybe you can try a different cam or something thatll up the torque a bit?
Old 03-27-2005, 01:17 AM
12 Second Truck Club
Magic Chicken's Avatar
very interesting
Old 03-27-2005, 06:24 AM
bigeller's Avatar
Interesting.. Did you change anything else? Was the tune tweaked any at all? Was the weather different at all from the initial dyno? Heat, Humidity?
I'd keep the 1 7/8" on there.. Those are some mighty impressive numbers..
Old 03-27-2005, 09:06 AM
383ss's Avatar
damn, I completely forgot. I added a TNT power ring also. I meant to take it off before the dyno, but it slipped my mind not sure if that would have made any difference ???
by the way, this is a 99% track car, so the gains are valid and worth it to me. well, maybe not worth the $400 I spent to upgrade to these, but at least I got something out of it, although it hasn't shown at the track yet. I've been there twice with this setup now and have not run any better. ALTHOUGH I was using the same shift points as the 1 3/4 setup, so I'm hoping that is the difference. will get track results friday.
tune was not tweaked and I did not get A/F. the meter wasn't working at the dyno weather conditions were very similar between dyno's.
Old 03-27-2005, 09:10 AM
383ss's Avatar
Old 03-27-2005, 09:16 AM
383ss's Avatar
also look at the gains from 6000+ it goes from about a 5hp gain there to 30+ hp from 6500 up. if you are really spinning your setup, these would definatly be the way to go.
Old 03-27-2005, 01:01 PM
dug
dug's Avatar
You probably would have made more power with macs.
Just kidding. Vince had similar results with his 408 in his vette.
What determines primary tube size anyways? Engine displacement or hp?
Old 03-27-2005, 01:33 PM
Green Thunder's Avatar
hmmm That is very interesting...
Old 03-27-2005, 04:01 PM
02WS6Bird's Avatar
How much taht puppy needs to BREATH, so in most cases displacment but cam specs come in there as well
Old 03-28-2005, 07:07 AM
383ss's Avatar
I do have to add...
these heads 'only' flow 293@600 lift and have 2.02/1.60 valves. so much for big valves/peak numbers!!
Old 03-28-2005, 08:49 AM
gator's 99TA's Avatar
john its going to make a big differnce on the spray. believe me.
Old 03-28-2005, 06:17 PM
"All Motor 9 Second club member"
TXCAMSS's Avatar
That's surprising to me. I recently had HPE swap my FLP 1 3/4 headers to the Kooks
1 7/8 headers and through a single 3 inch cut-out in the same conditions and same dyno. I went from 446 rwhp to 459 rwhp and I had them install a new Mosier 12 bolt rearend with 3.73 gears at the same time the Kooks were installed. I figure I lost 10-15 rwhp from the 12 bolt over my previous 10 bolt 3.23s. I was tuned in for each set though and no bottle on the wifes' car so a N2O ring wasn't an issue. Every car is different. I am running an HPE 383 Stroker for comparison purposes. I'd check that A/F tune. There just might be a bit more hidden in there. Good luck!!!
Old 03-28-2005, 06:31 PM
verbs's Avatar
exactly
Old 03-28-2005, 06:54 PM
02WS6Bird's Avatar
Why is that? freer flowing exhausts seem to take well to spray vs. freer flowing intake
Old 03-28-2005, 07:23 PM
BADFNZ's Avatar
More N2O=More HP=More CFM=Bigger primaries needed
Quick Reply: 1 3/4 vs 1 7/8 header dyno RESULTS!!!
