Any way to convert 2nd gear hp to 3rd gear hp?
I dynoed my truck this weekend, the first pull was done in 3rd gear, but we hit the factory speed limit at 4000 rpm. The rest of the pulls were done in 2nd gear up to 5900 rpm, and the curves are noticeably lower than the 3rd gear curve. Is there a way to convert the 2nd gear numbers to what they would have been in 3rd gear?
Thanks
Thanks
On my dyno print out, it looks like all the 2nd gear pulls are about 15-20 hp and tq less than the portion of the 3rd gear pull that was done. Is it safe to assume that would continue to hold true above 4000 rpm? I was hoping there would be a mathematical way to convert it so that when I dyno after my cam swap with the speed limiter removed, I'd have a true before and after comparison.
LS1TECH Sponsor
Originally Posted by 98t56TA
Did you check out my stock graph? There were two lines one for 2nd another for 3rd. Peak hp started to approach the value in 3rd.
